> Installing Bearings and Hubs, ...another step-by-step
Eric_Shea
post May 17 2004, 11:08 AM
PMB Performance
After Saturday’s bushings install came Sunday’s bearing install. The factory manual can be quite vague on most subjects; lessons that become clear only after doing it so… hopefully this can clear things up a bit regarding installing rear bearings:
Step 1 – If you haven’t taken out your old bearings then you’ll want to do that. If the hub is in then you’ll need to drive it out of the control arm. This varies from a “light tap” to a “full blown slam”. You will ruin your old bearing but… that’s what we’re doing here. Find a suitable drift. Porsche calls it a P297a (better known as a suitable drift). I use an old 911 rear torsion bar. Once the hub is out you’ll need to drive out the bearing. Again, a vague reference to a “suitable thrust piece” to drive it out. After the hub is out you’ll see the lip on the backside of the bearing. Use a hardened punch and slowly tap out the bearing moving the punch from 9:00 to 3:00 to 12:00 to 6:00… you get the picture. Slowly so you don’t lodge it sideways in the bearing pocket and damage the control arm. Make sure the punch is resting on the bearing edge and not scoring the pocket surface. Save an old bearing housing…
Eric_Shea
post May 17 2004, 11:15 AM
PMB Performance
The install tool...
Eric_Shea   Installing Bearings and Hubs   May 17 2004, 11:08 AM
Eric_Shea   Step 2 – Freeze your bearings. Do this as soon ...   May 17 2004, 11:09 AM
Eric_Shea   Step 3 – Prep the arm. I like to lightly rub so...   May 17 2004, 11:09 AM
Eric_Shea   Step 4 – Install your now frozen bearings. I’...   May 17 2004, 11:10 AM
Eric_Shea   Step 5 – Once the bearings are in, install the b...   May 17 2004, 11:11 AM
Eric_Shea   Step 6 – Now it’s the time to reinstall the hu...   May 17 2004, 11:12 AM
Eric_Shea   Getting started...   May 17 2004, 11:13 AM
Eric_Shea   Getting closer...   May 17 2004, 11:13 AM
Eric_Shea   Hub drawn in...   May 17 2004, 11:14 AM
Eric_Shea   The install tool...   May 17 2004, 11:15 AM
william harris   :trophy: Go directly to the Classics threads! ...   May 17 2004, 01:10 PM
Eric_Shea   Right on Chief! Glad it could help. I was wo...   May 17 2004, 01:57 PM
tat2dphreak   great info dude!! :trophy:   May 17 2004, 02:07 PM
Targa   Very clean Eric! I only have one question: Whe...   May 17 2004, 02:19 PM
watsonrx13   A fantastic and comprehensive article. Thanks fo...   May 17 2004, 02:23 PM
Eric_Shea
  May 17 2004, 03:12 PM
seanery   Great Job Eric! I plan on printing this threa...   May 17 2004, 03:20 PM
John2kx   Eric, Great job on the procedure you used. Exact...   May 17 2004, 04:04 PM
Eric_Shea   Look at that frozen hub... great idea! :troph...   May 17 2004, 04:33 PM
seanery   let me get this straight: 1. freeze bearing & hub...   May 17 2004, 05:43 PM
Jeffs9146   I used a shop light to raise the temp of the Beari...   May 17 2004, 05:50 PM
415PB   Great job Eric. Thanks   May 17 2004, 06:04 PM
ThinAir914   Is there any of this that is different for those o...   May 17 2004, 11:39 PM
David_S   One of the things we do at work where we have real...   May 17 2004, 11:58 PM
SpecialK   <...   May 18 2004, 01:18 AM
ber914   Can this be done with the control arm on the car o...   May 18 2004, 01:34 AM
John2kx   <...   May 18 2004, 02:18 AM
Eric_Shea   And now... you can find them in the classifieds :...   May 18 2004, 06:32 PM
HalfMoon   Hmmm... I was just speaking with Glenn at Pelican ...   Jan 2 2014, 02:26 PM
Eric_Shea   Hmmm... I was just speaking with Glenn at Pelican...   Jan 2 2014, 03:09 PM
Chris H.   I think you just set the thread bump age record......   Jan 2 2014, 02:34 PM
HalfMoon   Chuckle, I'm famous :bullshit: Here's so...   Jan 2 2014, 02:59 PM
HalfMoon   Valuable link by the way. TY D I think you just ...   Jan 2 2014, 03:01 PM
HalfMoon   Actually I think Glenn was referring to the danger...   Jan 2 2014, 03:26 PM
jfort   Thanks, Eric. If I ever have to do this job, I...   Jan 2 2014, 03:59 PM
HalfMoon   Btw, do I recall a thread that stated what tools w...   Jan 2 2014, 11:23 PM
02loftsmoor   this is good information, the tricks that make it ...   Jan 3 2014, 09:12 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 05:35 AM
