1.7 Vs. 2.0 D-jet, Throttle body FI? |
Bob L. |
Mar 12 2012, 06:44 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I'm guessing the injectors would have to be swapped out but are there any problems adapting it?
(IMG:style_emoticons/default/confused24.gif) Thanks. |
underthetire |
Mar 13 2012, 09:52 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I will add that since 2.0 Djet parts are getting almost impossible to get now, and 1.7 not much easier, was the main reason i went megasquirt. It allows you to be able to change/update any component in the FI system and program around it. It can be done very cheap compared to good/new replacement parts. I think I had ~300 in the entire system. (using stock injectors/runners/throttle body)
Bob L. |
Mar 13 2012, 10:44 AM
I will add that since 2.0 Djet parts are getting almost impossible to get now, and 1.7 not much easier, was the main reason i went megasquirt. It allows you to be able to change/update any component in the FI system and program around it. It can be done very cheap compared to good/new replacement parts. I think I had ~300 in the entire system. (using stock injectors/runners/throttle body) $300. is not bad at all. What did you start with? I have no FI parts now. What would I need from the old system and what new? I assume It'll be more $ for me since I need runners and some other stuff. I have read a few threads about mega/micro squirt. I just can't get a sense of the actual costs involved. I think Micro would be fine for me. I like the idea of keeping the FI and modernizing it as well. Has anyone done a simple microsquirt conversion on a 1.7? Honestly, what's the realistic price range? |
Lo-Fi Version | Time is now: 25th June 2024 - 08:01 PM |
