> Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo
Mike Bellis
post Mar 4 2012, 09:45 PM
Resident Electrician
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining.
http://www.914world.com/bbs2/index.php?showtopic=113156
With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull.
The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage.
As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts.
Here's some pics of the package...
Mike Bellis
post Mar 13 2012, 09:47 PM
Here is the engine mated to the tranny... I only had to pull off the upper intake manifold to remove the engine. And, that was only due to the lack of a proper lift. All accessories will bolt on before reinstallation.
Here you can just see the tab on the black water pump housing I had to grind for clearance. The later oil pump cover has a divot to clear this tab. This is a common mod when using this setup. The main advantage is the mechanical control of the oil meetering pump. The electronic control I was using is a POS. The guy that sells it is too hard to get hold of in Austrailia. So the simple cable setup will work every time.
kg6dxn   Official Sasquatch Re Build Thread   Mar 4 2012, 09:45 PM
Andyrew   Aaaand subscribed :)   Mar 4 2012, 11:02 PM
kg6dxn   It will be a miracle if I get it going by WCR. But...   Mar 4 2012, 11:19 PM
kg6dxn   Progress! I found an out of work guy that jus...   Mar 12 2012, 08:31 PM
strawman   The main difference on this engine is the oil inj...   Mar 13 2012, 10:34 PM
kg6dxn   The main difference on this engine is the oil in...   Mar 13 2012, 10:45 PM
Rand   I'm stoked for you. I've been anxiously an...   Mar 12 2012, 08:41 PM
Andyrew   Wooot!!   Mar 13 2012, 08:54 AM
matthepcat   Congrats Mike. Good Karma kickin in for all the he...   Mar 13 2012, 09:12 AM
Lennies914   Great news Mike. Are you saying that the apex se...   Mar 13 2012, 05:41 PM
kg6dxn   Great news Mike. Are you saying that the apex s...   Mar 13 2012, 09:00 PM
Jeffs9146   Wow you got motivation! It looks like you and...   Mar 13 2012, 09:24 PM
kg6dxn   Here is the engine mated to the tranny... I only h...   Mar 13 2012, 09:47 PM
Lennies914   Was it the controller you are unhappy with, or the...   Mar 13 2012, 10:03 PM
kg6dxn   Was it the controller you are unhappy with, or th...   Mar 13 2012, 10:47 PM
kg6dxn   Well the engine will be in this weekend but it won...   Mar 16 2012, 11:30 PM
JRust   Nice Mike. Glad to see you flying on your car agai...   Mar 17 2012, 01:36 PM
kg6dxn   Got the engine and tranny mocked up. I use aircraf...   Mar 17 2012, 10:42 PM
kg6dxn   Glamour shots...   Mar 17 2012, 10:44 PM
wingnut86   That might be the 1st RUST I've seen on a Cali...   Mar 17 2012, 10:46 PM
falconfp2001   I read both your threads tonight and I'm now a...   Mar 23 2012, 01:13 AM
ChrisNPDrider   Great news Mike! :beer2: WCR is a long shot...   Mar 23 2012, 03:32 PM
kg6dxn   Thanks guys! I got all the misc pieces and AN...   Mar 23 2012, 06:37 PM
kg6dxn   Minor set back. As described before, Mazda has 10 ...   Mar 25 2012, 09:27 AM
matthepcat   Sounds like its time to use some vacation days :)   Mar 25 2012, 02:25 PM
kg6dxn   Sounds like its time to use some vacation days :)...   Mar 25 2012, 08:00 PM
kg6dxn   Engine ready to go back in... You can see the s...   Mar 27 2012, 09:49 PM
kg6dxn   Got the motor/tranny in. Exhaust on. I had to clea...   Mar 31 2012, 11:18 PM
kg6dxn   I got everything under the car assembled today. Re...   Apr 1 2012, 10:29 PM
matthepcat   Lookin' good. You might be able to drive down...   Apr 2 2012, 01:24 PM
kg6dxn   Got the fuel system done today. Fired up the pump,...   Apr 7 2012, 11:45 PM
oldschool   Got the fuel system done today. Fired up the pump...   Apr 8 2012, 01:34 AM
kg6dxn   great job dude....if I wan't shooting a web T...   Apr 8 2012, 08:34 AM
oldschool   great job dude....if I wan't shooting a web ...   Apr 8 2012, 09:57 PM
strawman   Congrats Mike! Glad to see you're making p...   Apr 8 2012, 12:53 AM
kg6dxn   The new upper intake mocked into place. The new TB...   Apr 8 2012, 09:24 AM
kg6dxn   Got the Terrycable clutch cable in and the throttl...   Apr 8 2012, 09:42 PM
kg6dxn   Engine is back together!!! :Qarl: To...   Apr 13 2012, 10:39 PM
JRust   Nice Mike :driving-girl: Hope the drive goes grea...   Apr 13 2012, 11:05 PM
Cairo94507   Cool! I hope to see you cruising around town M...   Apr 14 2012, 06:31 AM
Lennies914   Way to go Mike. Looks great. :Qarl:   Apr 14 2012, 08:09 AM
Rotary'14   Your rebuild looks even better!,, I can't ...   Apr 14 2012, 10:26 AM
kg6dxn   Got it running and out on the road. :Qarl: The t...   Apr 14 2012, 08:36 PM
Rotary'14   that was quick   Apr 14 2012, 08:39 PM
jsconst   That awesome, glad you were able to get it going. ...   Apr 14 2012, 10:07 PM
JRust   Way to go Mike :driving: . Wish I could be at WCR ...   Apr 15 2012, 12:09 AM
slothness   Love the sound, this car is going to be a beast. N...   Apr 15 2012, 12:23 AM
ruby914   Love the sound, this car is going to be a beast. ...   Apr 15 2012, 09:47 AM
Lennies914   Love that "shit eatin grin" on the video...   Apr 15 2012, 07:43 AM
kg6dxn   Thanks for all the encouragement! oh, Lennie,...   Apr 15 2012, 10:39 AM
matthepcat   Sweet. Hope to see you spank my v8. Btw do I see ...   Apr 15 2012, 08:09 PM
Andyrew   Woo Hoo!!   Apr 15 2012, 11:36 PM
kg6dxn   Running way too rich right now. O2 says I'm at...   Apr 16 2012, 08:35 AM
kg6dxn   Well WCR was the first real outing with the turbo ...   Apr 30 2012, 10:57 PM
Lennies914   Why not de-tune it? :confused: ...   Apr 30 2012, 11:12 PM
kg6dxn   Why not de-tune it? :confused: And then do anot...   Apr 30 2012, 11:18 PM
Andyrew   OHhhh Man! :) Thats exactly my thoughts as ...   Apr 30 2012, 11:18 PM
Rand   It doesn't get any nicer than an LS1. Too com...   Apr 30 2012, 11:29 PM
kg6dxn   It doesn't get any nicer than an LS1. Too co...   Apr 30 2012, 11:34 PM
Rand   It doesn't get any nicer than an LS1. Too c...   Apr 30 2012, 11:40 PM
dakotaewing   [quote name='kg6dxn' post='1674360' date='Apr 30 ...   May 1 2012, 08:28 AM
Andyrew   Neither does 3k.. Oh and you can part out the rest...   Apr 30 2012, 11:48 PM
Rand   Think about it. What do you want in the end? (Cons...   May 1 2012, 01:48 AM
kg6dxn   Look what followed me home today. Can you say dono...   May 2 2012, 11:12 PM
Andyrew   YEEEAHH! You wont find any more HP than what...   May 2 2012, 11:50 PM
jeeperjohn56   Hey Mike, The old lady next door is going to have ...   May 15 2012, 05:03 AM
kg6dxn   It's in the garage right now. 914, still under...   May 15 2012, 10:55 AM
oldschool   It's in the garage right now. 914, still unde...   May 15 2012, 11:45 AM
Andyrew   Boxter trani, Well that blows the budget right out...   May 15 2012, 11:28 AM
kg6dxn   Boxter trani, Well that blows the budget right ou...   May 15 2012, 04:05 PM
Rand   Psst. Hey. Ecotec 1000hp, smaller displacement. Re...   May 15 2012, 02:20 PM
kg6dxn   Psst. Hey. Ecotec 1000hp, smaller displacement. R...   May 15 2012, 03:28 PM
Rand   Psst. Hey. Ecotec 1000hp, smaller displacement. ...   May 15 2012, 03:34 PM
Lennies914   :blink: :D EJ25D with 5 speed Too much ...   May 15 2012, 05:46 PM
kg6dxn   EJ25D with 5 speed Too much time on CL while t...   May 15 2012, 05:57 PM
Lennies914   EJ25D with 5 speed Too much time on CL while ...   May 15 2012, 06:01 PM
kg6dxn   This is going to be a throttle by wire install. In...   May 15 2012, 05:52 PM
Lennies914   Mike, Have you considered using the pedal assy. fr...   May 15 2012, 05:58 PM
kg6dxn   Mike, Have you considered using the pedal assy. f...   May 15 2012, 06:08 PM
Lennies914   I'm thinking of cutting out the entire front f...   May 15 2012, 06:46 PM
Andyrew   Any update? :)   Jun 6 2012, 08:59 AM
kg6dxn   Any update? :) My back's been too fuched up ...   Jun 6 2012, 09:39 AM
slothness   Any update? :) My back's been too fuched up...   Jun 6 2012, 10:13 AM
kg6dxn   Yikes! Take it easy there Mike. We all know y...   Jun 6 2012, 01:45 PM
Andyrew   If I can sway you... The GT28 is an AMAZING turbo ...   Jun 6 2012, 10:04 AM
Andyrew   Also, Ouch on the nerve.. Hope you feel better...   Jun 6 2012, 10:06 AM
McMark   My understanding it that the K03 shaft is supporte...   Jun 6 2012, 12:09 PM
kg6dxn   My understanding it that the K03 shaft is support...   Jun 6 2012, 01:43 PM
wingnut86   What a great idea on using the Subie firewall. Af...   Jun 6 2012, 12:28 PM
35 User(s) are reading this topic (35 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th November 2024 - 03:41 AM
