benalishhero |
Member ![]() ![]() Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States ![]() |
Hey guys, I thought I'd pick your brains on this one. If you could knock some ideas around that would be great. I'm stuck on this one.
First off, all the baseline stuff is in order. e.g. valves, ignition, fuel pressure, vacuum etc.. The motor starts fine cold or warm, and idles fine. However it will not take gas off a stop. It will go with about 1/4 throttle if I feather it. If I punch it immediately it dies. I can also, if up to a fair speed, full throttle it(through the bog) and back it off just a bit and it will take off. Basically it's fine at idle and at full enrich. I'm suspecting a dead-spot in the TPS. (IMG:style_emoticons/default/confused24.gif). Can a bad CHT cause poor acceleration? Enjoy the day Thomas |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Stuck advance in the Dizzy?
Lo-Fi Version | Time is now: 24th June 2024 - 07:37 AM |
