dlee1967 |
V8Lurker ![]() ![]() ![]() Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None ![]() |
Before the flamers get started...YES, I have searched and searched.....even on the Lambo Lounge and GT40 forums.
I am interested in any pictures of the case machining and welding required when flipping the differential on an early (short) 930 transaxle for fitment in a 914. A shot of the inside of the bellhousing to show the added kick out for the ring gear on the other side is what I am most interested in as the 930 pressure plate comes in pretty deep and care must be taken to make sure you don't have any contact by making the kick out too high. The electronic speedo sender is a bit of a no brainer, but please post what you have. I am aware of setting the backlash and how critical this is in providing long life of the gearbox. No need to rehash this. I am aware of the shops that provide this service and what they charge. I am aware of the technique for inverting the box, but want to maintain a full trunk on a street car and don't care to add a spray bar system in the box. Thank you. Attached image(s) ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Well, I guess I just needed to look again. This wasn't my project, I just took pics. Some DAPO had tried to solve the issue with epoxy/JBWeld. It didn't work. (IMG:style_emoticons/default/rolleyes.gif)
This got welded up in the bellhousing area. Attached image(s) ![]() ![]() ![]() ![]() |
dlee1967 |
Geeze Mark....that sure is ugly. After the DAPO butcher job it is a wonder you wanted to touch it. After you welded up the mess in the bell housing was any material taken off the ring gear or the selector shaft?
Thanks for the pics. These should be the "how not to flip your 930 diff". David Lee |
Lo-Fi Version | Time is now: 24th June 2024 - 07:24 AM |
