falconfp2001 |
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region ![]() |
I'm just starting my Megasquirt Install prep and need to mount my AFR Gauge. I'll mount it first because it can run independently of the MEgasquirt.
I don't want to cut my lower pad or my upper pad as they are nearly perfect and I like to keep the look as stock as possible. Any suggestions or maybe pics of how you have added gauges would be much appreciated. I have a 1971 1.7L with stock injection. I want to mount the Gauge under the dash just a little left of the center point of the dash. Any suggestions? |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
The ashtray location works great for mounting two VDO or other 2 1/16" gauges. VDO makes a bracket out of rubber that can easily be cut to fit (simply remove the angled top section and drill two holes to utilize the stock ashtray mounting holes). The location makes it easy to see the gauges, and is reversible as no parts of the dash were cut to do the install.
Lo-Fi Version | Time is now: 20th June 2024 - 05:22 AM |
