Als914 |
Lighting my way ![]() ![]() Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California ![]() |
Hello all,
With all the parts stash I collected over the years it's time to put the five lug Fuch's on my narrow body, '74 picture below. ![]() I have 6x16 front and 7x16 rear. The rears will be using a converted four lug to five lug hub w/ powder coated trailing arms and new bearings and bushings. I don't anticipate using any wheel spacers. The studs that I plan to use for the front rotors are the M14 x 1.5 x ?? screw in type. My question is, what is the length of the stud I should buy? Where can I buy them? Any help would be appreciated. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit. Some cars fit them better than others but some tugging rolling WILL be required to get 205's on 7's back there. 205's on 6" are a better bet and still require a lip massage.... I've seen narrowed trailing arms done to fit 7's under stock fenders.. but thats a LOT of work. Do you need some PMB 4 lug to 5 lug hubs? (Just surplus'd the set that was on my car....) |
Als914 |
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit. Some cars fit them better than others but some tugging rolling WILL be required to get 205's on 7's back there. 205's on 6" are a better bet and still require a lip massage.... I've seen narrowed trailing arms done to fit 7's under stock fenders.. but thats a LOT of work. Do you need some PMB 4 lug to 5 lug hubs? (Just surplus'd the set that was on my car....) Got them Aaron, Thanks |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:41 PM |
