Center or 3rd seat belt., anyone add one? |
Ferg |
Mar 16 2012, 11:12 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect.
I assume you use the same mounting points/bolt as the two receptacle's already in place. Anybody do this with a aftermarket or rear 911 or 944 lap belt? I have access to both. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Don't have the car yet to "lay" it out in person, just thinking ahead of what's involved... Ferg. |
SirAndy |
Mar 16 2012, 12:27 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect. I assume you use the same mounting points/bolt as the two receptacle's already in place. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Well, you should have done your homework beforehand ... (IMG:style_emoticons/default/rolleyes.gif) The center seat belts mount to a set of special threaded holes on the floorpan. Those mounting holes only exists on *early* cars! If what you ordered is a original center belt, it probably won't fit the same mounting point as the normal seatbelts. This is for early models only. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 25th September 2024 - 11:02 PM |
