Center or 3rd seat belt., anyone add one? |
Ferg |
Mar 16 2012, 11:12 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect.
I assume you use the same mounting points/bolt as the two receptacle's already in place. Anybody do this with a aftermarket or rear 911 or 944 lap belt? I have access to both. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Don't have the car yet to "lay" it out in person, just thinking ahead of what's involved... Ferg. |
Tom_T |
Mar 16 2012, 01:36 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Ferg,
What we did in our 88 Westy which has the narrower rear seat than the standard Vanagon, was to add an extra belt for the middle using the same mount points with a bit longer bolt to accommodate 2 seatbelt end plats' thickness. The same should work on a 914. So unless you're trying to stay all original, I'd suggest you get a lap belt that will fit & with the angled plate or bend one to match, or use flat if not an issue. IIRC the 2+1 seating option wasn't offered after 72 MY, & only outside of the US; or it may have only been 70-71 MYs with the fixed pass. seat - I'm not sure. However, the center position seating is really tough with a center console, which is why my PO/OO had removed the Center Console before I bought my early 73 2L in 12/75, in order to seat their 2 kids for ferrying around in the 914 (3rd kid on the way was why they sold). BTW - some of the early 73 MY production bodies from Aug. or so 72 still had the extra mount point in the floor. Yours may since IIRC it's an early VIN. So I agree with Andy to wait, then see what you have & go from there. IIRC, that early 914 optional center belt was like the non-retracting rear seatbelts used in 1960's & early 70's Bugs, Ghias, Buses, 411s/412s, etc., so that may be an alternative source for used, NOS, new repro &/or reconditioned ones that would be close to or same as OE. Maybe post some pix on here as a guide to how you do it, if you do, for others to see if they want to tackle it. I may even do it if I have the extra mounts in my 8/72 built 73 2L! (IMG:style_emoticons/default/idea.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Ferg |
Mar 16 2012, 01:55 PM
Ferg, What we did in our 88 Westy which has the narrower rear seat than the standard Vanagon, was to add an extra belt for the middle using the same mount points with a bit longer bolt to accommodate 2 seatbelt end plats' thickness. The same should work on a 914. So unless you're trying to stay all original, I'd suggest you get a lap belt that will fit & with the angled plate or bend one to match, or use flat if not an issue. IIRC the 2+1 seating option wasn't offered after 72 MY, & only outside of the US; or it may have only been 70-71 MYs with the fixed pass. seat - I'm not sure. However, the center position seating is really tough with a center console, which is why my PO/OO had removed the Center Console before I bought my early 73 2L in 12/75, in order to seat their 2 kids for ferrying around in the 914 (3rd kid on the way was why they sold). BTW - some of the early 73 MY production bodies from Aug. or so 72 still had the extra mount point in the floor. Yours may since IIRC it's an early VIN. So I agree with Andy to wait, then see what you have & go from there. IIRC, that early 914 optional center belt was like the non-retracting rear seatbelts used in 1960's & early 70's Bugs, Ghias, Buses, 411s/412s, etc., so that may be an alternative source for used, NOS, new repro &/or reconditioned ones that would be close to or same as OE. Maybe post some pix on here as a guide to how you do it, if you do, for others to see if they want to tackle it. I may even do it if I have the extra mounts in my 8/72 built 73 2L! (IMG:style_emoticons/default/idea.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Yup, when I get the car I'll look into doing just that. No center console in this car... Just want it for driving the little one's to the corner ice cream/coffee shop, like 2nd gear residential speeds. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:52 AM |
