sweathappens |
Newbie ![]() Group: Members Posts: 22 Joined: 25-February 06 From: Prunedale Member No.: 5,636 ![]() |
Re: My 1974 2.0 914.
I have had this car since about 1990. a couple of years ago I needed to rebuild the engine. I bought a rebuilt motor and the heads came loose. I took it to a local mechanic to re torque the heads. He could only get to the bottom four bolts on each cylinder as I expected. He said they torqued but one of the studs felt funny and suggested I rebuild the motor. I let him do the rebuild and he said the heads felt fine now. They came loose again. He says he didn't use head gaskets as they were not needed. I want to get this thing running right again. Why are my heads coming loose? Do I need gaskets on this motor. Some mechanics I have talked to say I need head gaskets and others say no. It would be interesting and helpful for you guys to chime in on this subject. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yes, the factory used laminated metal gaskets.
HAM doesn't. Raby doesn't. Clay, Cap'n Krusty, and others do. Frequently, each will be able to tell you in detail (with quite a few examples) why "their" way is correct and the "other" way is wrong. --DD |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,191 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
[quote name='Dave_Darling' date='M Frequently, each will be able to tell you in detail (with quite a few examples) why "their" way is correct and the "other" way is wrong.
--DD [/quote] which IMHO is a lot more useful than it sounds at first. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:06 AM |
