battery drain, Is my generator bad? |
ruby914 |
Mar 17 2012, 03:52 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
The WRX914 has a battery drain. Pulled all fuses, relays, grounds. No change.
I ended up at the generator? I pulled the two big white wires off (coming from the battery) and removed the plug with two small wires. The pole that the two big wires went to has continuity to ground. Is this telling me that the $200 generator is bad? |
mrbubblehead |
Mar 17 2012, 04:05 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
The WRX914 has a battery drain. Pulled all fuses, relays, grounds. No change. I ended up at the generator? I pulled the two big white wires off (coming from the battery) and removed the plug with two small wires. The pole that the two big wires went to has continuity to ground. Is this telling me that the $200 generator is bad? your generator may have turned itself into a motor. have you checked the voltage regulator? |
Lo-Fi Version | Time is now: 26th December 2024 - 06:25 PM |
