> battery drain, Is my generator bad?
ruby914
post Mar 17 2012, 03:52 PM
The WRX914 has a battery drain. Pulled all fuses, relays, grounds. No change.
I ended up at the generator?
I pulled the two big white wires off (coming from the battery) and removed the plug with two small wires. The pole that the two big wires went to has continuity to ground.
Is this telling me that the $200 generator is bad?
ruby914
post Mar 17 2012, 05:52 PM
I just checked the truck and there is no continuity through the alternator like the WRX.
(IMG:style_emoticons/default/sad.gif)
Last week I blew some fuses and lost my head light motors for some unknown reason. They all work now. (IMG:style_emoticons/default/idea.gif)
ruby914   battery drain   Mar 17 2012, 03:52 PM
mrbubblehead   The WRX914 has a battery drain. Pulled all fuses,...   Mar 17 2012, 04:05 PM
ruby914   The WRX914 has a battery drain. Pulled all fuses...   Mar 17 2012, 05:05 PM
mrbubblehead   [quote name='mrbubblehead' post='1648031' date='M...   Mar 17 2012, 05:21 PM
ruby914   Best I can tell, the system is charging fine but w...   Mar 17 2012, 05:28 PM
mrbubblehead   Best I can tell, the system is charging fine but ...   Mar 17 2012, 05:42 PM
ruby914   I just checked the truck and there is no continuit...   Mar 17 2012, 05:52 PM
mrbubblehead   I just checked the truck and there is no continui...   Mar 17 2012, 06:29 PM
mrbubblehead   I just checked the truck and there is no continu...   Mar 17 2012, 06:33 PM
ruby914   [quote name='mrbubblehead' post='1648103' date='M...   Mar 17 2012, 06:47 PM
ruby914   I just checked the truck and there is no continu...   Mar 17 2012, 07:03 PM
mrbubblehead   hmmm, my next suggestion was going to be to discon...   Mar 17 2012, 07:27 PM
ruby914   Well, I took it down to Pepboys and they tested th...   Mar 17 2012, 08:12 PM
mrbubblehead   Well, I took it down to Pepboys and they tested t...   Mar 17 2012, 08:18 PM
ruby914   Well, I took it down to Pepboys and they tested t...   Mar 18 2012, 03:09 PM
mrbubblehead   what a nightmare bro..... so your gonna reinstall...   Mar 18 2012, 03:23 PM
ruby914   what a nightmare bro..... so your gonna reinstal...   Mar 18 2012, 03:45 PM
mrbubblehead   what a nightmare bro..... so your gonna reinsta...   Mar 18 2012, 03:50 PM
ruby914   [quote name='ruby914' post='1648521' date='Mar 18...   Mar 18 2012, 03:57 PM
mrbubblehead   LOL.... i would bet its the alt. did your battery ...   Mar 18 2012, 04:03 PM
Tom   Your testing the alternator with on ohmmeter soun...   Mar 18 2012, 06:49 PM
ruby914   Your testing the alternator with on ohmmeter sou...   Mar 18 2012, 08:32 PM
Tom   The load I read on the multimeter with everything ...   Mar 19 2012, 03:19 AM
ruby914   The load I read on the multimeter with everything...   Mar 19 2012, 01:59 PM
Tom   I just took readings on mine and I am reading in t...   Mar 19 2012, 02:41 PM
ruby914   I just took readings on mine and I am reading in ...   Mar 23 2012, 01:26 AM
mrholland2   I just took readings on mine and I am reading in...   Mar 24 2012, 10:45 AM
ruby914   Ok, so they don't fix them selves. Guess I did...   Mar 30 2012, 01:55 PM
Tom   You don't have to multiply the reading. The DC...   Mar 31 2012, 11:08 AM
- Lo-Fi Version Time is now: 26th December 2024 - 06:50 PM
