battery drain, Is my generator bad? |
ruby914 |
Mar 17 2012, 03:52 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
The WRX914 has a battery drain. Pulled all fuses, relays, grounds. No change.
I ended up at the generator? I pulled the two big white wires off (coming from the battery) and removed the plug with two small wires. The pole that the two big wires went to has continuity to ground. Is this telling me that the $200 generator is bad? |
ruby914 |
Mar 17 2012, 05:52 PM
I just checked the truck and there is no continuity through the alternator like the WRX.
(IMG:style_emoticons/default/sad.gif) Last week I blew some fuses and lost my head light motors for some unknown reason. They all work now. (IMG:style_emoticons/default/idea.gif) |
mrbubblehead |
Mar 17 2012, 06:29 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I just checked the truck and there is no continuity through the alternator like the WRX. (IMG:style_emoticons/default/sad.gif) Last week I blew some fuses and lost my head light motors for some unknown reason. They all work now. (IMG:style_emoticons/default/idea.gif) were they blown, or did they blow when you pulled on the switch? |
mrbubblehead |
Mar 17 2012, 06:33 PM
I just checked the truck and there is no continuity through the alternator like the WRX. (IMG:style_emoticons/default/sad.gif) Last week I blew some fuses and lost my head light motors for some unknown reason. They all work now. (IMG:style_emoticons/default/idea.gif) were they blown, or did they blow when you pulled on the switch? is your alternator fairly new? or is its life unknown? |
ruby914 |
Mar 17 2012, 06:47 PM
I just checked the truck and there is no continuity through the alternator like the WRX. (IMG:style_emoticons/default/sad.gif) Last week I blew some fuses and lost my head light motors for some unknown reason. They all work now. (IMG:style_emoticons/default/idea.gif) were they blown, or did they blow when you pulled on the switch? is your alternator fairly new? or is its life unknown? unknown or about 60k miles that was on the wrx that was installed. Now that I have the alternator out, I check continuity through and get nothing with the black lead to the terminal and red to the body. With the red lead to the terminal and black to body I get resistance. I thought it didn't matter + or _ with continuity. I went back to the truck and did the same and got the same. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/wacko.gif) So it's good (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 06:30 PM |
