battery drain, Is my generator bad? |
ruby914 |
Mar 17 2012, 03:52 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
The WRX914 has a battery drain. Pulled all fuses, relays, grounds. No change.
I ended up at the generator? I pulled the two big white wires off (coming from the battery) and removed the plug with two small wires. The pole that the two big wires went to has continuity to ground. Is this telling me that the $200 generator is bad? |
ruby914 |
Mar 17 2012, 08:12 PM
Well, I took it down to Pepboys and they tested the alternator. Said it was bad.
Not one to trust their test I took it to O'Rielys, they said the same. On the 2nd test I was able to get a detailed report of what failed, an overcharging regulator. I think it's time to throw some money at it. Thanks for the help. |
Lo-Fi Version | Time is now: 26th December 2024 - 06:48 PM |
