blank page engine rebuild, what would you do? |
Type 47 |
Mar 15 2012, 06:54 PM
Senior Member Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage.
I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. |
wndsrfr |
Mar 17 2012, 08:06 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage. I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. Grab the HAM heads dada is selling. Send the case & heads to len hoffman for decking & any refresh,, he will do it right. Plug the oil galleys too. Bore your oem cylinders to 96mm. Get Jakes cam & a set of pistons, KBs ok for street, JEs for track. Get the rotating assembly balanced. Set deck height to get 10: 1 CR. Put on a high volume full flow oil filter & cooler. Get Chris' s headers (tangerine). Fill with Brad Penn oil. Start it up & just try to wipe that huge grin off your face!! Priceless! |
Type 47 |
Mar 18 2012, 12:08 PM
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage. I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. Grab the HAM heads dada is selling. Send the case & heads to len hoffman for decking & any refresh,, he will do it right. Plug the oil galleys too. Bore your oem cylinders to 96mm. Get Jakes cam & a set of pistons, KBs ok for street, JEs for track. Get the rotating assembly balanced. Set deck height to get 10: 1 CR. Put on a high volume full flow oil filter & cooler. Get Chris' s headers (tangerine). Fill with Brad Penn oil. Start it up & just try to wipe that huge grin off your face!! Priceless! This sound like a good setup too...same question as above...HP, torque, carb/FI, cost? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:12 PM |
