Group Buy for 4 channel CHT Gauge Kit, ---ARRIVED--- Shipping Thursday 4/26/12 |
jsayre914 |
Mar 16 2012, 03:47 PM
Speed Up !!! Group: Members Posts: 3,199 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Well, after speaking with the Owner, founder of MGL this is the absolute best price we are gonna get. If anybody wants this gauge, now is the time to let me know. I will leave this thread till Monday and we will see if we have any takers.
$375.00 price includes.
Thread that started this GROUP BUY TC-2 Manual The CHT Sensor (IMG:style_emoticons/default/popcorn[1].gif) |
stugray |
Mar 18 2012, 07:38 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE i could probley fab 100 tc's in an hour... I used to make TCs for the Space sim lab at Lockheed Martin. To do it right you need to twist the ends and spot weld them with a tiny bench-top welder. Then we would put the tip in an oven and heat them to ~200C and then dip them in Liquid Nitrogen (-180C), then right back in the oven. If they survived that, they were good to go. That type would be acceptable for clamping directly under a spark plug once or twice. I wouldnt trust that much more than that unless you had a "washer" type protective sheath. If you wanted to make them for EGTs, then they would need a threaded "probe". Stu |
mrbubblehead |
Mar 18 2012, 08:43 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
QUOTE i could probley fab 100 tc's in an hour... I used to make TCs for the Space sim lab at Lockheed Martin. To do it right you need to twist the ends and spot weld them with a tiny bench-top welder. Then we would put the tip in an oven and heat them to ~200C and then dip them in Liquid Nitrogen (-180C), then right back in the oven. If they survived that, they were good to go. That type would be acceptable for clamping directly under a spark plug once or twice. I wouldnt trust that much more than that unless you had a "washer" type protective sheath. If you wanted to make them for EGTs, then they would need a threaded "probe". Stu ya, i didnt use that process when i made mine. i used the ol strip and crimp method. might not be good enough for the space shuttle, but it worked perfectly on my 914. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 20th September 2024 - 04:52 PM |
