Black914_4 |
Member ![]() ![]() Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States ![]() |
Stock 74 with 2.0. D-jet
I havent had much time to work on the car lately. Fairly nice day today so I through a battery in it and drove it to town. 5-6 miles one way. On the way back it started cutting out. idles fine but won't take any gas. I push the gas pedal and it just cuts outs. pulled over. shut it off and fired it back up. Ran good for about a mile and started to cut out again if I gave it any gas. Shut it off while still rolling about 45, turned it back on and it ran for just a min before starting agin. Made it home... barely ???? Any clue what it might be? Thanks for the help |
Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
Another, less likely, possibility is the fuel pump. I spent a long time diagnosing a similar issue that was caused by my pump failing at operating temp. As long as the engine was still warming up it pumped, but then would loose all pressure at once at a certain temp. I had to stick a pressure gauge on it and notice the pressure drop right before the engine died. The pump remained running, just no pressure. |
Lo-Fi Version | Time is now: 27th June 2024 - 11:10 PM |
