Rick - I need your help, chassis twist |
TravisNeff |
Mar 17 2012, 10:20 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
A few years ago I got a new welder, I welded everthing in site... Needless to say I never understood shrinkage.
I installed an Engman kit and not only did I rosette weld the kit in, I fully stiched the whole thing. The end result, a stiff chassis - but a bent tub. My door gaps are totally fuquered. My passenger rear fender was replaced and they must have welded the front, then the back and I have a weird bubble in my fender well. So not everthing is the same.. My passenger side gap has been messed up since I got the car, huge gap at the back of the door. Here's my measurements, not to be reconciled with the factor charts too much, I am sure I am measuring from different dimensions than that. Anyways my measurements are from the same spots side to side Targa opening D 62.7, P 63.5 CM Latch to hinge D 110.5, P 110.5 CM Diag mid latch plate to top of targa D 109.4, P 108.4 Front bulkead to targa, D 42.6, P 141.5 My guess is: the passenger cowl fell in, so did the drivers side The drivers targa fell in, passenger stayed staticd (lots of welding on the e-brake area) Pics to follow.... |
TravisNeff |
Mar 18 2012, 09:23 PM
My plan is to cut through the stiffening kit at the cowl on both sides. push out the passenger side first, then driver side. next make a cut in the stiffening kit at the rear of the drivers door and push the drivers side targa bar back.
Sound like the right approach? |
rick 918-S |
Mar 18 2012, 09:27 PM
Hey nice rack! -Celette Group: Members Posts: 20,841 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
My plan is to cut through the stiffening kit at the cowl on both sides. push out the passenger side first, then driver side. next make a cut in the stiffening kit at the rear of the drivers door and push the drivers side targa bar back. Sound like the right approach? That sounds reasonable. But you should be sure to put in a support through the door opening before you weld again. Edit: also pull the catches off the "B" pillar so you car adjust the doors without any interference from the latch. Once your done welding and the doors swing free and line up you can replace the catch. |
Lo-Fi Version | Time is now: 17th January 2025 - 07:35 AM |
