Rick - I need your help, chassis twist |
TravisNeff |
Mar 17 2012, 10:20 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
A few years ago I got a new welder, I welded everthing in site... Needless to say I never understood shrinkage.
I installed an Engman kit and not only did I rosette weld the kit in, I fully stiched the whole thing. The end result, a stiff chassis - but a bent tub. My door gaps are totally fuquered. My passenger rear fender was replaced and they must have welded the front, then the back and I have a weird bubble in my fender well. So not everthing is the same.. My passenger side gap has been messed up since I got the car, huge gap at the back of the door. Here's my measurements, not to be reconciled with the factor charts too much, I am sure I am measuring from different dimensions than that. Anyways my measurements are from the same spots side to side Targa opening D 62.7, P 63.5 CM Latch to hinge D 110.5, P 110.5 CM Diag mid latch plate to top of targa D 109.4, P 108.4 Front bulkead to targa, D 42.6, P 141.5 My guess is: the passenger cowl fell in, so did the drivers side The drivers targa fell in, passenger stayed staticd (lots of welding on the e-brake area) Pics to follow.... |
TravisNeff |
Mar 18 2012, 09:41 PM
So I will make my cuts here in the front
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th January 2025 - 07:50 AM |
