Rick - I need your help, chassis twist |
TravisNeff |
Mar 17 2012, 10:20 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
A few years ago I got a new welder, I welded everthing in site... Needless to say I never understood shrinkage.
I installed an Engman kit and not only did I rosette weld the kit in, I fully stiched the whole thing. The end result, a stiff chassis - but a bent tub. My door gaps are totally fuquered. My passenger rear fender was replaced and they must have welded the front, then the back and I have a weird bubble in my fender well. So not everthing is the same.. My passenger side gap has been messed up since I got the car, huge gap at the back of the door. Here's my measurements, not to be reconciled with the factor charts too much, I am sure I am measuring from different dimensions than that. Anyways my measurements are from the same spots side to side Targa opening D 62.7, P 63.5 CM Latch to hinge D 110.5, P 110.5 CM Diag mid latch plate to top of targa D 109.4, P 108.4 Front bulkead to targa, D 42.6, P 141.5 My guess is: the passenger cowl fell in, so did the drivers side The drivers targa fell in, passenger stayed staticd (lots of welding on the e-brake area) Pics to follow.... |
TravisNeff |
Mar 18 2012, 10:59 PM
Rear catches are out, front quarter windows & caps are out too. door panels tomorrow and let the cutting begin.
one last question, i will put the porta power at the base of the long and the rear firewall, the front, I presume that i will push on the panel flange at the upper hinge height (or should it be higher?) |
rick 918-S |
Mar 18 2012, 11:16 PM
Hey nice rack! -Celette Group: Members Posts: 20,841 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Rear catches are out, front quarter windows & caps are out too. door panels tomorrow and let the cutting begin. one last question, i will put the porta power at the base of the long and the rear firewall, the front, I presume that i will push on the panel flange at the upper hinge height (or should it be higher?) Stay about the upper hinge height. Use blocks of wood or thick rubber pads and watch to see that your not crushing the pressure points where the port-o-power cintacts the body. The windsheild frame should be in the right place. Don't tweek that unless your vent window is binding. It shouldn't be.. |
Lo-Fi Version | Time is now: 17th January 2025 - 07:34 AM |
