Type 47 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None ![]() ![]() |
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage.
I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. |
shuie |
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 ![]() |
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts.
Type 47 |
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks |
shuie |
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks Dyno showed 153hp and 175ft. lbs of torque @ 4500RPM, 44mm carbs, no MSD. Id guess ~$8k total cost with shipping, sourcing parts, etc... You could probably get it done cheaper. I had a lot of extra costs here because of the issues with my core. |
Type 47 |
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks Dyno showed 153hp and 175ft. lbs of torque @ 4500RPM, 44mm carbs, no MSD. Id guess ~$8k total cost with shipping, sourcing parts, etc... You could probably get it done cheaper. I had a lot of extra costs here because of the issues with my core. Wow, those #'s are incredible |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:48 PM |
