tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I set my end play to .003 on my rebuild. Before installing the engine, I decided to change to a lighter flywheel. Do I need to check end play again? I know it isn't a huge deal to check end play but I just found that my dial indicator is busted.
tornik550 |
I just tried to check end play with the new flywheel (I found an old dial indicator). With the new flywheel, I am getting zero movement. Looks like I need to change the shims. Do I have to remove the rear main seal to remove the shims? (I don't want to go back outside tonight so I figured I would just ask)
mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
I just tried to check end play with the new flywheel. With the new flywheel, I am getting zero movement. Looks like I need to change the shims. Do I have to remove the rear main seal to remove the shims? (I don't want to go back outside tonight so I figured I would just ask) unfortunately yes, the seal has to come out to get to the shims. and remember, you need 3 shims. no more no less. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:26 PM |
