Boxster Calipers, got them installed today! |
SirAndy |
Feb 27 2012, 01:12 AM
Resident German Group: Admin Posts: 41,893 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
About time too as my Carrera brake pads were down to the metal.
The idea was simple, get rid of the Carrera Calipers and mount Boxster Calipers all around using the mounting adapters from Rich Johnson. Of course, nothing ever goes as planned: (IMG:style_emoticons/default/headbang.gif) First, i failed to read Rich's instructions that clearly state that you have to use a 20mm 911 SC rear rotor. Well, i have 24mm Carrera rear rotors. The Boxster Calipers had to be machined (2mm off each of the brake pad pins) and the adapters had to be milled to center the Boxster Calipers over the wider rotors. (IMG:style_emoticons/default/smash.gif) Then, after everything was bolted together, i recalled reading that the hard brake lines may not be long enough. And sure enough (of course) the front brake lines were about 1" too short. Arrghhh. (IMG:style_emoticons/default/rolleyes.gif) McMark came to the rescue and we made two new lines. (IMG:style_emoticons/default/thumb3d.gif) In the rear, i used banjo fittings on the Calipers (Thanks to Eric Shea for those!) and the rear brakelines were no problem. Mark and i then bled the brakes. I was still getting some air in the front, but it was already 9pm so we decided to call it a night and i drove it home (40+ miles). The brakes actually felt fine, they seem to work great. I'll go back to the OC shop next weekend and we'll bleed them again. (IMG:style_emoticons/default/driving.gif) And now for the pitchers: (IMG:style_emoticons/default/beer3.gif) |
Cracker |
Mar 19 2012, 07:14 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Andy - Great job and the brakes look great. What, if anything are you doing regarding brake bias? Do you intend to use your car on the track? With all that volume it will be interesting to see if you end up with a larger MC. I had a 19 and moved up to a 23/930. Food for thought and always a slippery slope...
slivel |
Mar 19 2012, 08:02 PM
Old car....... older driver Group: Members Posts: 514 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Andy - Great job and the brakes look great. What, if anything are you doing regarding brake bias? Do you intend to use your car on the track? With all that volume it will be interesting to see if you end up with a larger MC. I had a 19 and moved up to a 23/930. Food for thought and always a slippery slope... Don't know what Andy is running for a M/C but I have a 23 mm and it was a very hard pedal with the Carerra/Carerra and Boxster/Carerra combo. I think that it will be very good and easy to modulate with the Boxster fr/rr combo. |
okieflyr |
Mar 19 2012, 08:19 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Andy - Great job and the brakes look great. What, if anything are you doing regarding brake bias? Do you intend to use your car on the track? With all that volume it will be interesting to see if you end up with a larger MC. I had a 19 and moved up to a 23/930. Food for thought and always a slippery slope... Don't know what Andy is running for a M/C but I have a 23 mm and it was a very hard pedal with the Carerra/Carerra and Boxster/Carerra combo. I think that it will be very good and easy to modulate with the Boxster fr/rr combo. I've been using a 23mm mc as well and it does give a hard pedal on my Boxster setup too. I think i'd like a little more leveraged feel with something in the 21mm range, but I would imagine the 19mm being a little more travel range than I'd be comfortable with. I am curious what pads people are using for the 914, given the lack of vacuum assist and generally cooler operating temps (in my case anyway). |
Cracker |
Mar 20 2012, 04:23 AM
Okieflyer wrote: "...but I would imagine the 19mm being a little more travel range than I'd be comfortable with."
Yeah, at 150+ into a downhill 90-degree corner... I like a HARD pedal, knowing the brakes are REALLY there. Auto-x is completely diferent...your "life" is not on the line. Keep us posted as you are able to get some time with the brakes. Once again, it's an attractive set-up! |
Lo-Fi Version | Time is now: 24th November 2024 - 04:58 PM |
