2.0 Djet problem, Will not take gas. Idles fine |
benalishhero |
Mar 15 2012, 01:09 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Hey guys, I thought I'd pick your brains on this one. If you could knock some ideas around that would be great. I'm stuck on this one.
First off, all the baseline stuff is in order. e.g. valves, ignition, fuel pressure, vacuum etc.. The motor starts fine cold or warm, and idles fine. However it will not take gas off a stop. It will go with about 1/4 throttle if I feather it. If I punch it immediately it dies. I can also, if up to a fair speed, full throttle it(through the bog) and back it off just a bit and it will take off. Basically it's fine at idle and at full enrich. I'm suspecting a dead-spot in the TPS. (IMG:style_emoticons/default/confused24.gif). Can a bad CHT cause poor acceleration? Enjoy the day Thomas |
benalishhero |
Mar 20 2012, 07:34 AM
Well I'm back to the original problem. The car will start right up, run for a few seconds then die. After it dies I can restart it 1st crank. Man, I'm going in circles!!!
Rich: thanks for the offer. I may take you up on that. Prospect: cold reading is 1.5Kohms. I think that out of range for an 012. Should be pushing 3kohms at room temp. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:31 AM |
