DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Here is what I lose:
Tach, fuel level, oil temp gauge, volt meter. Then the red alt. Light is on, but car runssmoother, it was not right before that. This is a 75 2.0. D-jet new coil not long ago, I have a hotspark module, no issues with it seems to be fine.. Had been running really good. All lights stay on except I think the brake light, that could be the culprit? . I will recheck that. What else is on this circuit? I thought tomorrow I would disconnet the fuel level sender, maybe that is the cause? |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Fuse #9 has nothing to do with the AAR.
AAR is fused off of the rear fuse on the relay panel AND at 25 amps is fused too high. I use an 8 amp for mine as I don't have the heater blower hooked up and no rear window defrost. The wire for the AAR is only good for about 20 amps before becoming so hot it melts surrounding wires, so if you fuse that one at 25 and and your AAR shorts out partially, it can fry the AAR wire and surrounding wires. If you do have the heater blower hooked up, using a 16 amp fuse will be good, but carry a back-up. An alternative is to put an inline fuse at the junction where the AAR wire hooks up to your harness wire and fuse it a 5 amps. Be a crying shame to fry that brand new ignition harness! Tom |
Lo-Fi Version | Time is now: 24th June 2024 - 07:15 AM |
