ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
I must be missing it, but I can't find it on the Haynes schematic.
falconfp2001 |
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region ![]() |
According to the Pelican Schematic, it should be a green with black stripe.
rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
do you have a multimeter or some way to check continuity?
If you look at where the wire bundle is routed through the engine tin under the battery, there is a single wire that breaks out of the bundle right there. This is the oil temp sender connection. You can check continuity from that spade terminal to the wires in your harness and find it that way. |
rwilner |
do you have a multimeter or some way to check continuity? If you look at where the wire bundle is routed through the engine tin under the battery, there is a single wire that breaks out of the bundle right there. This is the oil temp sender connection. You can check continuity from that spade terminal to the wires in your harness and find it that way. here's the connector I'm talking about (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1332293997.1.JPG) |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:20 PM |
