jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Like the title says, what year 911 flywheel do I need so my 2.4 6 will bolt up to my 901?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
You can also use a "915" flywheel (225mm) IF you use a 70 or 71 911 clutch disk and the pull type arm from a 70 or 71 911. It will also involve moving the pivot point inside the 901 bell housing to accommodate the different length of the arm.
The advantages are that you can use a straight cable with no pulley on the transmission to work the clutch. And don't anyone say this doesn't work, as I ran it on my car for 2 years. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:14 PM |
