what do you carry for spares?, tools, parts, etc. |
mrbubblehead |
Mar 21 2012, 07:23 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
like the title says, what do you guys carry for spares in your daily driving? i try to travel light, but i think i have all the bases covered.
share what you carry. heres my list, 1. a pair of thin coveralls. 2. hazet tool kit (from an old car) 3. the little black bag. 3a. varies 3/8 metric sockets 3b. 3/8 ratchet 3c. little cresent wrench 3d. tie wraps 3e. roll of black tape 3f. little bit of tie wire 4. clutch cable 5. throttle cable 6. oil pressure sensor 7. points, condenser, cap and rotor. (im running a petronix..but you never know) 8. clutch tube repair kit 9. the little plastic chingus on the end of the clutch cable to clutch throw out arm. 10. the little pin chingus for the clutch cable pedal end (it was cheap- what the hell) 11.fan belt 12. little mag light 13. 2 round relays (tested) 14. lug wrench 15. spare tire 16. stock jack (perfect for my lowered car) 17. bike chain (in case i have to chain it to a post or something) 18. dozen fuses (reds and whites) 19. 1 qt of oil things i know i need to add, spare fuel pump (facet) various lamps (maybe a brake, turn signal, running lamp) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379418.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379419.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332379419.3.jpg) |
Tom_T |
Mar 21 2012, 07:32 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Nice setup!
I've got a 16 bulb spare set & an 8 or 10 OEM fuse set (IIRC there were 3 or 4 amp sizes) as a back-up - which you mention both, but that is a more complete set Also add a red fuel pump relay & one for headlights & TS (unless they're already new). PP/Automotion/Ecklers, AA, Pelican & maybe others also sell them. Also make sure you have a good transaxle to chassis (under R trunk) ground cable with good connections, so that you won't need the acc. or clutch cables! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:34 PM |
