intake tube alignment, 3/4 tube to the distributor is off |
malcolm2 |
Mar 21 2012, 06:44 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Well, I did not pay enough attention as I was taking this engine apart. I cleaned, blasted and painted the intake tubes and the "intake distributor" (please correct me if I have mis-named). Anyway, I am a good 1/4" off center on the #3 cylinder intake tube, left tube. This can't be good or right, can it? I can get the short rubber hose on,
this kind of offset will leak right? the 1/2 side lines up nicely |
Valy |
Mar 21 2012, 07:14 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Is the air distribution box in the correct location? How are the other 2 j tubes?
Are left and right j tubes connected in the right place? Did you mix 1.8 and 2.0 components? |
malcolm2 |
Mar 21 2012, 07:36 PM
Is the air distribution box in the correct location? How are the other 2 j tubes? Are left and right j tubes connected in the right place? Did you mix 1.8 and 2.0 components? The box really won't go on any other way. the distance from the box pipes to the J-pipes is the same on both sides, 1 is just off center. German welder must have been in a hurry to go to lunch when he welded this one. |
Lo-Fi Version | Time is now: 20th October 2024 - 06:50 AM |
