> Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo
Mike Bellis
post Mar 4 2012, 09:45 PM
Resident Electrician
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining.
http://www.914world.com/bbs2/index.php?showtopic=113156
With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull.
The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage.
As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts.
Here's some pics of the package...
falconfp2001
post Mar 23 2012, 01:13 AM
Pancho Pantera
I read both your threads tonight and I'm now a big fan. Back in 1984, My second car that I bought was a 1974 rx-4 coupe. That thing was wicked fast stock. I ended up installing dual exhaust headers, hi flow mufflers and I re-jetted the stock four barrel. I had a very good Mazda mechanic tune it then cut the front springs and install Koni's all around. The rear was a leaf suspension so I installed stiffening bars. Back then, I would blow away stock Porsche's no problem. It had a stock 4 port 13B with stock 4 barrel that I re-jetted. I would scare people with how fast I drove that car.
Later (1987) I bought a second generation rx-7. I never changed a thing on that car and it was fast. Handled like a dream around corners. Just had my mechanic tune it and that was all.
In 1994 I purchased a 1974 Mazda Rotary Pickup. Rebuilt the 13B, re-jetted the stock 4 barrel and installed a rx-7 5 speed tranny, Racing Beat intake and Dellorto side draft carb. Also put on a Racing Beat Exhaust headers and dual exhaust to the rear with nice mufflers. Had 8 inch front wheels and 11 inch rears. I also found a LS differential for it. Fastest car I ever owned. I could chirp the tires in second gear and redline in second was past 60. Never really found out the top speed of that car but it was quick and so much lighter than the others.
I so wish I could find another truck or Rx-2, rx-3 for a good price but they are really expensive now. Always wanted to turbo one just to see the potential as I've been a big fan of those engines. The only negative is the MPG. They suck down that gas if you have a heavy foot.
I'll be watching with interest.
kg6dxn   Official Sasquatch Re Build Thread   Mar 4 2012, 09:45 PM
Andyrew   Aaaand subscribed :)   Mar 4 2012, 11:02 PM
kg6dxn   It will be a miracle if I get it going by WCR. But...   Mar 4 2012, 11:19 PM
kg6dxn   Progress! I found an out of work guy that jus...   Mar 12 2012, 08:31 PM
strawman   The main difference on this engine is the oil inj...   Mar 13 2012, 10:34 PM
kg6dxn   The main difference on this engine is the oil in...   Mar 13 2012, 10:45 PM
Rand   I'm stoked for you. I've been anxiously an...   Mar 12 2012, 08:41 PM
Andyrew   Wooot!!   Mar 13 2012, 08:54 AM
matthepcat   Congrats Mike. Good Karma kickin in for all the he...   Mar 13 2012, 09:12 AM
Lennies914   Great news Mike. Are you saying that the apex se...   Mar 13 2012, 05:41 PM
kg6dxn   Great news Mike. Are you saying that the apex s...   Mar 13 2012, 09:00 PM
Jeffs9146   Wow you got motivation! It looks like you and...   Mar 13 2012, 09:24 PM
kg6dxn   Here is the engine mated to the tranny... I only h...   Mar 13 2012, 09:47 PM
Lennies914   Was it the controller you are unhappy with, or the...   Mar 13 2012, 10:03 PM
kg6dxn   Was it the controller you are unhappy with, or th...   Mar 13 2012, 10:47 PM
kg6dxn   Well the engine will be in this weekend but it won...   Mar 16 2012, 11:30 PM
JRust   Nice Mike. Glad to see you flying on your car agai...   Mar 17 2012, 01:36 PM
kg6dxn   Got the engine and tranny mocked up. I use aircraf...   Mar 17 2012, 10:42 PM
kg6dxn   Glamour shots...   Mar 17 2012, 10:44 PM
wingnut86   That might be the 1st RUST I've seen on a Cali...   Mar 17 2012, 10:46 PM
falconfp2001   I read both your threads tonight and I'm now a...   Mar 23 2012, 01:13 AM
ChrisNPDrider   Great news Mike! :beer2: WCR is a long shot...   Mar 23 2012, 03:32 PM
kg6dxn   Thanks guys! I got all the misc pieces and AN...   Mar 23 2012, 06:37 PM
kg6dxn   Minor set back. As described before, Mazda has 10 ...   Mar 25 2012, 09:27 AM
matthepcat   Sounds like its time to use some vacation days :)   Mar 25 2012, 02:25 PM
kg6dxn   Sounds like its time to use some vacation days :)...   Mar 25 2012, 08:00 PM
kg6dxn   Engine ready to go back in... You can see the s...   Mar 27 2012, 09:49 PM
kg6dxn   Got the motor/tranny in. Exhaust on. I had to clea...   Mar 31 2012, 11:18 PM
kg6dxn   I got everything under the car assembled today. Re...   Apr 1 2012, 10:29 PM
matthepcat   Lookin' good. You might be able to drive down...   Apr 2 2012, 01:24 PM
kg6dxn   Got the fuel system done today. Fired up the pump,...   Apr 7 2012, 11:45 PM
oldschool   Got the fuel system done today. Fired up the pump...   Apr 8 2012, 01:34 AM
kg6dxn   great job dude....if I wan't shooting a web T...   Apr 8 2012, 08:34 AM
oldschool   great job dude....if I wan't shooting a web ...   Apr 8 2012, 09:57 PM
strawman   Congrats Mike! Glad to see you're making p...   Apr 8 2012, 12:53 AM
kg6dxn   The new upper intake mocked into place. The new TB...   Apr 8 2012, 09:24 AM
kg6dxn   Got the Terrycable clutch cable in and the throttl...   Apr 8 2012, 09:42 PM
kg6dxn   Engine is back together!!! :Qarl: To...   Apr 13 2012, 10:39 PM
JRust   Nice Mike :driving-girl: Hope the drive goes grea...   Apr 13 2012, 11:05 PM
Cairo94507   Cool! I hope to see you cruising around town M...   Apr 14 2012, 06:31 AM
Lennies914   Way to go Mike. Looks great. :Qarl:   Apr 14 2012, 08:09 AM
Rotary'14   Your rebuild looks even better!,, I can't ...   Apr 14 2012, 10:26 AM
kg6dxn   Got it running and out on the road. :Qarl: The t...   Apr 14 2012, 08:36 PM
Rotary'14   that was quick   Apr 14 2012, 08:39 PM
jsconst   That awesome, glad you were able to get it going. ...   Apr 14 2012, 10:07 PM
JRust   Way to go Mike :driving: . Wish I could be at WCR ...   Apr 15 2012, 12:09 AM
slothness   Love the sound, this car is going to be a beast. N...   Apr 15 2012, 12:23 AM
ruby914   Love the sound, this car is going to be a beast. ...   Apr 15 2012, 09:47 AM
Lennies914   Love that "shit eatin grin" on the video...   Apr 15 2012, 07:43 AM
kg6dxn   Thanks for all the encouragement! oh, Lennie,...   Apr 15 2012, 10:39 AM
matthepcat   Sweet. Hope to see you spank my v8. Btw do I see ...   Apr 15 2012, 08:09 PM
Andyrew   Woo Hoo!!   Apr 15 2012, 11:36 PM
kg6dxn   Running way too rich right now. O2 says I'm at...   Apr 16 2012, 08:35 AM
kg6dxn   Well WCR was the first real outing with the turbo ...   Apr 30 2012, 10:57 PM
Lennies914   Why not de-tune it? :confused: ...   Apr 30 2012, 11:12 PM
kg6dxn   Why not de-tune it? :confused: And then do anot...   Apr 30 2012, 11:18 PM
Andyrew   OHhhh Man! :) Thats exactly my thoughts as ...   Apr 30 2012, 11:18 PM
Rand   It doesn't get any nicer than an LS1. Too com...   Apr 30 2012, 11:29 PM
kg6dxn   It doesn't get any nicer than an LS1. Too co...   Apr 30 2012, 11:34 PM
Rand   It doesn't get any nicer than an LS1. Too c...   Apr 30 2012, 11:40 PM
dakotaewing   [quote name='kg6dxn' post='1674360' date='Apr 30 ...   May 1 2012, 08:28 AM
Andyrew   Neither does 3k.. Oh and you can part out the rest...   Apr 30 2012, 11:48 PM
Rand   Think about it. What do you want in the end? (Cons...   May 1 2012, 01:48 AM
kg6dxn   Look what followed me home today. Can you say dono...   May 2 2012, 11:12 PM
Andyrew   YEEEAHH! You wont find any more HP than what...   May 2 2012, 11:50 PM
jeeperjohn56   Hey Mike, The old lady next door is going to have ...   May 15 2012, 05:03 AM
kg6dxn   It's in the garage right now. 914, still under...   May 15 2012, 10:55 AM
oldschool   It's in the garage right now. 914, still unde...   May 15 2012, 11:45 AM
Andyrew   Boxter trani, Well that blows the budget right out...   May 15 2012, 11:28 AM
kg6dxn   Boxter trani, Well that blows the budget right ou...   May 15 2012, 04:05 PM
Rand   Psst. Hey. Ecotec 1000hp, smaller displacement. Re...   May 15 2012, 02:20 PM
kg6dxn   Psst. Hey. Ecotec 1000hp, smaller displacement. R...   May 15 2012, 03:28 PM
Rand   Psst. Hey. Ecotec 1000hp, smaller displacement. ...   May 15 2012, 03:34 PM
Lennies914   :blink: :D EJ25D with 5 speed Too much ...   May 15 2012, 05:46 PM
kg6dxn   EJ25D with 5 speed Too much time on CL while t...   May 15 2012, 05:57 PM
Lennies914   EJ25D with 5 speed Too much time on CL while ...   May 15 2012, 06:01 PM
kg6dxn   This is going to be a throttle by wire install. In...   May 15 2012, 05:52 PM
Lennies914   Mike, Have you considered using the pedal assy. fr...   May 15 2012, 05:58 PM
kg6dxn   Mike, Have you considered using the pedal assy. f...   May 15 2012, 06:08 PM
Lennies914   I'm thinking of cutting out the entire front f...   May 15 2012, 06:46 PM
Andyrew   Any update? :)   Jun 6 2012, 08:59 AM
kg6dxn   Any update? :) My back's been too fuched up ...   Jun 6 2012, 09:39 AM
slothness   Any update? :) My back's been too fuched up...   Jun 6 2012, 10:13 AM
kg6dxn   Yikes! Take it easy there Mike. We all know y...   Jun 6 2012, 01:45 PM
Andyrew   If I can sway you... The GT28 is an AMAZING turbo ...   Jun 6 2012, 10:04 AM
Andyrew   Also, Ouch on the nerve.. Hope you feel better...   Jun 6 2012, 10:06 AM
McMark   My understanding it that the K03 shaft is supporte...   Jun 6 2012, 12:09 PM
kg6dxn   My understanding it that the K03 shaft is support...   Jun 6 2012, 01:43 PM
wingnut86   What a great idea on using the Subie firewall. Af...   Jun 6 2012, 12:28 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th November 2024 - 03:25 AM
