> Steel Flares and Steel Rockers, Can this combination be found or, ...........
c12croft
post Mar 26 2012, 06:38 PM
Steel flares, or fender flares in general , fit compatibly with the fiberglass, ABS rockers in order to maintain the correct line of the flare, or so I always thought??
See photo of similar car:
This otherwise precludes the use of Steel Rockers, which I've always only saw in the fully straight/ flat style:
Am I correct in this conclusion?
Or are the steel rocker ends worked to maintain the flared fender lines?
Or can the steel rockers with pre-flared ends be found by some aftermarket supplier?
c12croft
post Mar 26 2012, 09:54 PM
I mean the ABS rockers can be made with the exact correct roll to match the roll of the steel fender flares. The problem is that the ABS rockers tend to be flimsy as compared to the steel rockers. Does any one else find this to be at issue or is the ABS a suitable replacement for the steel and leave it as is? Yi
- Lo-Fi Version Time is now: 6th January 2025 - 05:15 PM
