How does this target AFR table look?, VE table results after autotune |
rwilner |
Mar 28 2012, 08:36 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm going to use the autotune feature of Microsquirt to set my fuel map (VE table). This system will automatically adjust the VE to achieve the mixture as defined by the target AFR table.
This is a 12x12 table. The Y axis is MAP reading (load), and the X axis is RPM. This table was auto-generated by this microsquirt calculator. What do you guys think? Is this a solid target AFR table or are adjustments needed? |
aircooledtechguy |
Mar 28 2012, 09:08 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
Disclaimer: I can barely program my cell phone. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/biggrin.gif) I had someone much younger and MS savvy help me program my MS powered car. . .
If you're going for max power, then you will need an AFR in the high 11s low 12s where you are on the gas during hard WOT acceleration. My car leans out on cruise to 14-16 around 65-75 mph in high gear. Once I blip the gas it goes back into the 12s for power. I've got more tuning to do on mine. Now that I have a CHT gauge installed I will be better able to lean out the mixture to go after better fuel economy w/o worrying about cooking the heads. That table will get you started, but richening will give you power. |
Lo-Fi Version | Time is now: 19th September 2024 - 06:23 AM |
