How does this target AFR table look?, VE table results after autotune |
rwilner |
Mar 28 2012, 08:36 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm going to use the autotune feature of Microsquirt to set my fuel map (VE table). This system will automatically adjust the VE to achieve the mixture as defined by the target AFR table.
This is a 12x12 table. The Y axis is MAP reading (load), and the X axis is RPM. This table was auto-generated by this microsquirt calculator. What do you guys think? Is this a solid target AFR table or are adjustments needed? |
Andyrew |
Mar 28 2012, 09:20 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
You need to be low 12's high 11's for power. Especially with air cooled. Running lean will also create more heat...
mrbubblehead |
Mar 28 2012, 09:32 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
You need to be low 12's high 11's for power. Especially with air cooled. Running lean will also create more heat... how do you figure? (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1332948731.1.jpg) |
Lo-Fi Version | Time is now: 19th September 2024 - 06:15 AM |
