How does this target AFR table look?, VE table results after autotune |
rwilner |
Mar 28 2012, 08:36 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm going to use the autotune feature of Microsquirt to set my fuel map (VE table). This system will automatically adjust the VE to achieve the mixture as defined by the target AFR table.
This is a 12x12 table. The Y axis is MAP reading (load), and the X axis is RPM. This table was auto-generated by this microsquirt calculator. What do you guys think? Is this a solid target AFR table or are adjustments needed? |
polo classic |
Mar 28 2012, 12:52 PM
Newbie Group: Members Posts: 32 Joined: 7-October 11 From: Oslo Member No.: 13,650 Region Association: Scandinavia |
it is also better to start tuning from slightly rich
Lean -> hole in pistons Rich -> bore wash Hole in pistons happens faster than bore wash (IMG:style_emoticons/default/wink.gif) |
mrbubblehead |
Mar 28 2012, 03:19 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
it is also better to start tuning from slightly rich Lean -> hole in pistons Rich -> bore wash Hole in pistons happens faster than bore wash (IMG:style_emoticons/default/wink.gif) hmmmm? my car is as lean as i can get it. 16-17 at cruise......no holes yet. i drive 500 miles a week into las vegas and back. how can that be? look at the chart. lean is cooler. less fuel less heat. fuel is not a coolent. now at wot or 1/3 throttle and above (or load) i swing rich to 12.7 running rich under light load is a waste of fuel. you get no benefit.... BTDT |
Lo-Fi Version | Time is now: 19th September 2024 - 06:22 AM |
