Jack Stand Locations, Best/safest spots |
roundboy914 |
May 19 2004, 08:26 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
With all this talk of our cars on jack stands, i was wondering the best spots for the stands to be placed. I usually place the front pair right back of the front wheels, in the side channel on the floor (right inside of the rocker panel). The rear set, i put underneath the engine mountaing bar. Car seems balanced (doesn't move when i'm hauling my 300 pound carcass in and out while bleeding the brakes), i just wonder if it is the best spot.
ArtechnikA |
May 20 2004, 08:25 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(STL914 @ May 20 2004, 05:40 PM) Could you explain what you mean by diff carrier? the place where the case is bigger to accommodate the differential. directly between the axle flanges. where the drain plug is, IIRC... stay off the tunnel part at the back of the car, where the gear cluster is... the bellhousing wouldn't be bad, but it's a little too far forward to be as useful as you'd like ... |
Lo-Fi Version | Time is now: 26th November 2024 - 02:39 PM |
