> POR15 the fuel tank, Any experiences with the job ?
913B
post Mar 28 2012, 05:32 PM
So I read about the procedure, seems to cover a couple days and the left over chemicals to deal with. I wanted to hear from those members that have done it?
Is it too much of trouble and having to deal with it, did it come out ok, or are you pretty screwed if you dont follow the instructions exactly. Is there a shortcut maybe ?
Let me know your .02 cent
Thanks a bunch (IMG:style_emoticons/default/beerchug.gif)
Ted
Prospectfarms
post Mar 28 2012, 08:02 PM
QUOTE(porsche913b_sp @ Mar 28 2012, 07:32 PM) *
Ted
Done it countless times w/different machines. Two hours from removal to completion. 24 hours to dry.
1. Don't use pro15. Use Red-kote. Ebay. $20 I've used both. port15 failed, RK: never.
2. Got rust? Use 1/10 solution of acid du-jour to clean it. (I like muratic)
3. Swish it around with some chain or big nuts and bolts. I tape the opening with heavy duct tape.
4. Neutralize acid solution with baking soda. Pour it into a bucket and dispose on your neighbors yard.
5. Wash tank with BS then detergent, then water.
6. Blow it out with some air from a compressor, shop vac or hair dryer.
7. Pour in half of a quart of acetone, swish that around and remove.
8. Pour in the other half of acetone. You can save that for cleaning brushes or getting oil off metal.
9. A little more air, and your ready.
10 set the tank upright. Remove everything including the fuel nipples, follow directions on can of Red Kote + pour in about a pint, swish it everywhere, drain the excess back into the original container.
11. Put a fan on it. 24 hours till usable
Two notes:
The most dangerous thing about M acid is breathing the vapors when you open the bottle, or getting some splashed in your eye when you pour it into dilution. Not if you are careful. Acetone is less harmful to humans than de-natured alcohol. It just smells worse.
If you use acid, you can't let the tank sit to air dry or it will flash with surface rust. You don't have to use acid, it's just the only way I know how to get all the rust off.
Elliot Cannon
post Mar 28 2012, 10:26 PM
Group: Retired Members
QUOTE(Prospectfarms @ Mar 28 2012, 07:02 PM) *
Ted
Two notes:
I just took mine to a radiator shop and had it "boiled" out.
porsche913b_sp   POR15 the fuel tank   Mar 28 2012, 05:32 PM
Strudelwagon   Yup, Did this las summer. Pretty easy, just follow...   Mar 28 2012, 07:52 PM
porschefile2010   I did my tank about two months ago and the result ...   Mar 28 2012, 07:54 PM
porschefile2010   One other thing on drying. I used my wifes hair dr...   Mar 28 2012, 07:57 PM
Prospectfarms   So I read about the procedure, seems to cover a c...   Mar 28 2012, 08:02 PM
Elliot Cannon   So I read about the procedure, seems to cover a ...   Mar 28 2012, 10:26 PM
Elliot Cannon   I also heard this stuff works pretty well. Althou...   Mar 28 2012, 10:28 PM
Travis Neff   I did a ton of digging to see which kits can resis...   Mar 29 2012, 10:14 AM
ape914   for a light rust, just clean the tank, and use it,...   Mar 28 2012, 11:30 PM
Phoenix-MN   I Used KBS products. Worked great http://www.kbs...   Mar 29 2012, 04:59 AM
Prospectfarms   That's not practical advice. Radiator shops...   Mar 29 2012, 05:33 AM
vsg914   This is just my thoughts and is in no way a recomm...   Mar 29 2012, 06:52 AM
Prospectfarms   This is just my thoughts and is in no way a recom...   Mar 29 2012, 10:09 PM
ww914   I just did mine. Yes, it is a lot of work, but the...   Mar 29 2012, 08:47 AM
SUNAB914   I've used the Por-15 twice. No problems just a...   Mar 29 2012, 09:19 AM
sbsix   So I read about the procedure, seems to cover a c...   Mar 29 2012, 10:12 AM
porsche913b_sp   Thanks for all the tips guys, i really appreciate ...   Mar 29 2012, 05:33 PM
- Lo-Fi Version Time is now: 6th January 2025 - 08:33 PM
