How does this target AFR table look?, VE table results after autotune |
rwilner |
Mar 28 2012, 08:36 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm going to use the autotune feature of Microsquirt to set my fuel map (VE table). This system will automatically adjust the VE to achieve the mixture as defined by the target AFR table.
This is a 12x12 table. The Y axis is MAP reading (load), and the X axis is RPM. This table was auto-generated by this microsquirt calculator. What do you guys think? Is this a solid target AFR table or are adjustments needed? |
McMark |
Mar 29 2012, 10:20 AM
You might get a little power benefit from adding 'vacuum advance' in this area.
Attached image(s) |
rwilner |
Mar 29 2012, 10:39 AM
Lo-Fi Version | Time is now: 19th September 2024 - 06:13 AM |
