How does this target AFR table look?, VE table results after autotune |
rwilner |
Mar 28 2012, 08:36 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I'm going to use the autotune feature of Microsquirt to set my fuel map (VE table). This system will automatically adjust the VE to achieve the mixture as defined by the target AFR table.
This is a 12x12 table. The Y axis is MAP reading (load), and the X axis is RPM. This table was auto-generated by this microsquirt calculator. What do you guys think? Is this a solid target AFR table or are adjustments needed? |
ChrisFoley |
Mar 30 2012, 12:12 PM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
To me, hysteresis is when my wife says its cold and gets up to adjust the thermostat, then a little while later she says shes too hot and gets up to lower the setting on the t'stat - and so on ad infinitum. If the temperature changed instantaneously to match the t-stat setting there would be no need for her to ever get hysterical. (IMG:style_emoticons/default/rolleyes.gif)
rwilner |
Mar 30 2012, 12:14 PM
To me, hysteresis is when my wife says its cold and gets up to adjust the thermostat, then a little while later she says shes too hot and gets up to lower the setting on the t'stat - and so on ad infinitum. If the temperature changed instantaneously to match the t-stat setting there would be no need for her to ever get hysterical. (IMG:style_emoticons/default/rolleyes.gif) actually...thermostats have a built-in deadband...this is a special case of intentional hysteresis. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th September 2024 - 06:22 AM |
