jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
I'll be painting sometime soon and recently there has been several timely paint related threads. In the Midwest we're plagued by humid weather and lots of water in our compressed air. I figured I'd share my project to rid myself of water so my paint job isn't ruined.
There are several high dollar units out there to separate water from the air but I'm cheap. I decided to design some piping meant to drop the water out of suspension. All you need is 25' or more of piping, some valves, fittings and good old gravity. I wanted to use copper but it would have cost me over $150 in materials. Going with PVC cost me $40. I still need to finish the drain and inlet/outlet piping but you'll get the idea. Attached thumbnail(s) ![]() |
wingnut86 |
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States ![]() |
The biggest thing outside of pipe selection is again moisture.
The longer the runs, the better the ability of your 1st water separator to knock out moisture. Vertical height of 6' is a good minimum. 30% moisture drop is a good minimum after the 1st separator - And, I pulled that number outta my ass (IMG:style_emoticons/default/biggrin.gif) The higher the air consumption, the cooler the circuit runs. That's why home units tend to have more moisture in them. Keep your tools oiled daily... Always use disposable inline driers for paint guns if you can afford it, if not, keep a cookie sheet close to redry the huge amount of beads if using that method. Good Luck... |
Lo-Fi Version | Time is now: 12th March 2025 - 05:13 AM |
