ape914 |
red locktite ![]() ![]() Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None ![]() |
Just wondering if anyone has made up some data points on how a change of resistance in the head temp circuit effects the mixture?
I know of some one long ago that had installed an additional head temp resistor in line. They wired a variable resistor (potentiometer) all the way up to the dash so they could add enrichment on the fly. They had no airfuel meter so it was all seat of the pants. I am considering that a a possible fine tunning method on a D-jet 914. With an aftermarket cam, big bore pistons and non-stock compression ratio, I think there might be some room to add enrichment across the range. what I am thinking is to add an airfuel ratio meter, or go by head or exhaust temp as a guide, and adjust the mixture via this method and watch the gauges to try to find an optimal setting. Has anyone already tried this? How does head temp reistance effect the mixture? is it uniform across the rpm and load range? or does it only effect certain running conditions? Just begining the thought process on this, and dont want to re-invent the wheel if it has already been tried. By running a parallel reisistance, one could also lean out the mixture. I know some folks will tune the Pressure sensor (MPS) to change mixture, but I am thinking this is one more tunning tool maybe,and with a variable resistor wired to the dash, it can be changed on the fly, unlike MPS adjustments. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I really don't
I know exhaust probes we're the way to go for years and still are a great way to go but rich is good with a 914 motor so tuning to the absolute limit is not necessary on these all of tuning I've done has been with the innovates a hardwired gauge type... and a hand held type most of my experience has been tuning carbs and like I said, a couple of MPS's Attached image(s) ![]() |
Lo-Fi Version | Time is now: 1st July 2024 - 12:00 AM |
