pete |
Member ![]() ![]() Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States ![]() |
For you V8 guys. I'm getting close to installing my Renegade adapted 350 engine and I need to source (low budget) a complete cooling system. What will I need? Already started looking for the Gates Green Stripe hose. JEGS sells it in 10' lengths for around $135. Seems expensive.
I need to check dimensions but I was considering this radiator: http://www.ebay.com/itm/110799074907?ssPag...984.m1438.l2649 Can anyone offer advise on whether it will work? It doesn't have a drain. Cooling fans seem reasonable and again I will need to figure out dimensions but I was looking at these:http://www.ebay.com/itm/230669549138?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 I know I will need more "stuff". Is there a thread on a SBC cooling system? Can't seem to find one. Let me know. Thanks! |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE There seems to be an issue with air in the system which I'm a little confused about. Air in the system is bad and you need a way to get it out. This means you need access (a port) at the high point and a way to make sure the air gets there. |
Lo-Fi Version | Time is now: 19th April 2025 - 01:18 PM |
