> Clueless on COOLING, SBC cooling
pete
post Apr 5 2012, 07:57 AM
For you V8 guys. I'm getting close to installing my Renegade adapted 350 engine and I need to source (low budget) a complete cooling system. What will I need? Already started looking for the Gates Green Stripe hose. JEGS sells it in 10' lengths for around $135. Seems expensive.
I need to check dimensions but I was considering this radiator: http://www.ebay.com/itm/110799074907?ssPag...984.m1438.l2649
Can anyone offer advise on whether it will work? It doesn't have a drain.
Cooling fans seem reasonable and again I will need to figure out dimensions but I was looking at these:http://www.ebay.com/itm/230669549138?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I know I will need more "stuff". Is there a thread on a SBC cooling system? Can't seem to find one.
Let me know. Thanks!
ArtechnikA
post Apr 5 2012, 01:14 PM
rich herzog
There seems to be an issue with air in the system which I'm a little confused about.
Air in the system is bad and you need a way to get it out.
This means you need access (a port) at the high point and a way to make sure the air gets there.
pete
post Apr 5 2012, 01:23 PM
QUOTE(ArtechnikA @ Apr 5 2012, 03:14 PM) *
So am I running one of the 1 1/2" radiator hoses to a remote filler neck mounted in the engine area higher then the engine? And connecting a catch can to it as well?
- Lo-Fi Version Time is now: 19th April 2025 - 01:18 PM
