OT: Working on my shop car, The wagon Porsche never built. . . |
aircooledtechguy |
Dec 23 2011, 07:20 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
I've had a long term project going now to turn my '67 Squareback into my shop car. While I love driving my 914, it has limitations as a daily parts hauler. I love old styling with new technology and updates, so my goal is to turn my humble Square into the wagon that Porsche never made. I want it to drive and handle more like a Porsche than a VW wagon and it's got to be a true "Sleeper" (not a real problem; since it's a wagon). (IMG:style_emoticons/default/shades.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689630.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.2.jpg) This has been a 4-5 phase project. Phase-1 - Convert it to Porsche 914 2.0L motor. Make it physically adapted to the car and running MS2 w/ Ford EDIS ignition. Get it tuned to be a daily driver. DONE!! (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689631.3.jpg) Phase-2 - Make the motor look good and freshen it up with new P&Cs. The heads were freshened only about 2K miles before I got it, by me when it was in a clients 914 that he converted to Subie power. I noticed that once I had a few miles on it myself, it was using a bit of oil. So I upgraded to a new set of 96mm P&Cs. So now it's a 2056. I had my local powder coater do all the tins in black and the plenum and runners in grey for a stock look. I'm running T-4 H/Es with a modified bus header and a Summit Racing Flow Master clone muffler. So I had those ceramic coated in black so they are not attention grabbers from the back. This car is a sleeper (IMG:style_emoticons/default/happy11.gif) DONE!! Phase-3 - Convert the rear suspension to the later style IRS and install a Porsche 923 trans out of a Porsche 912E. The rear suspension is DONE!! While at it, I upgraded it with 914 rear brakes, urethane bushings, adjustable spring plates and a rear sway bar. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-9730-1324689632.4.jpg) Since the trans is taller than a stock 4-speed and cutting into the car can't happen due to rear seat issues. I gained the 1.5" I needed by spacing the body off the rear suspension with spacers. So here I sit, on the final leg of phase-3. I now need to couple the motor/trans and lift it into it's final place and fab rear engine hanger mounts for the rear bar. It's late and I'm tired. . . Phase-4 - Front suspension upgrade. Currently in-work Phase-5 - Paint so it doesn't look so crappy, though it does add to the "sleeper" persona. . . Stay tuned for more later. . . |
aircooledtechguy |
Apr 16 2012, 06:38 PM
Been sewing up details on the shop-car over the past few weekends. Finally got them all finished and can officially close out phase-3 (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif)
Fired the motor up and did some gear checks. Found all five so that''s good. Then out of the blue, my alternator let the magic smoke out (IMG:style_emoticons/default/headbang.gif) Luckily I have some spares around here (and it's easier to change than on the teener). I could have this beast prowling the back-roads by tomorrow afternoon. . . (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/driving.gif) I've decided that this is as far as I will take things this year. The front-end swap is as ambitious an undertaking as the 5-speed and also includes a power brake upgrade, so knowing how much I will actually have to dedicate to this during the busy months here at the shop it will be put on hold until next winter. I want to be able to drive and enjoy it for the upcoming show season and only do fine-tuning to the current set-up. I will be going ahead with custom widened wheels and tires though and adding in my 911 seats when the upholsterer gets them finished in a week or so. I also may fabricate a custom center console so I can move my gauges in there permanently. If I do, I'll probably wire-in the cruise control at that time. I do plan to have the MS2 re-tuned for the added displacement and CR when I upgraded from the stock U.S. spec 94s to the flat-top 96s. I know some have been interested in the gearing and what it would translate MPH = RPMs The preliminary tests on the gearing for the 923 (912E) trans are as follows (as indicated by the speed sensor in the trans and indicated by the 912E dash gauge I have installed and wired into the car)(RPMs are rounded): In 5th gear 40mph = 1700rpms 50mph = 2200rpms 60mph = 2600rpms 70mph = 3100rpms 80mph = 3600rpms 90mph = 4000rpms I didn't feel real comfortable running it faster than that on my lift in the shop with the tires only an inch or so off the ground. (IMG:style_emoticons/default/laugh.gif) I may have to wire in that cruise control sooner than later. . . (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 11:25 PM |
