2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
75 - 2.0
Dave Hunt and other victims: Just got 2-OH! started this weekend, still runs shitty, but that's another story... What I'm bothering you about is your exhaust leaks...I assume you had a bad seal between the heads, the copper gaskets and the manifolds... How did you know...and a quick and dirty on how you fixed em'...The nuts are torqued correctly, and honestly, I would hate to torque them any more...Afraid of breakage... With the car running, I get a pretty good downdraft of hot air if I hold my hand under the manifold area...Not scorching enough so that I have to move my hand but hot none-the-less...But is that blow-by or just the cooling fan/tin/ducting/cooling air moving over the cylinder heads doing it's job and exiting under the car... When running, it doesn't backfire or spit...How can I tell if the manifolds are sealed or not... New gaskets, new nuts, old manifolds but they fit right in, fresh head rework with a couple of new studs... 2-OH! |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Engine cooling air will be a constant velocity. Exhaust manifold leaks will have a "beat" that will quicken with engine rpm. The stock 75 headers are hard to seal, and can require a retorque after warmup.
Lo-Fi Version | Time is now: 24th June 2024 - 07:48 AM |
