FS: 1973 Console Gauges - 80, L Tail light - 40, (Prices Lowered) |
rnellums |
Feb 11 2012, 03:03 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Center Console Gauges - 80 obo - all functioning
Driver side Tail light - 40 obo - Very Good Shape |
rnellums |
Apr 18 2012, 04:41 PM
There are two hairline cracks at the leftmost side, and some more at the joints between the reverse light and the main panel. I am away from my computer right now so I can't upload pictures tonight. The cracks are only visible in strong sunlight from up close.
<!-- QuoteBegin Thorshammer+May 8 2005, 05:54 PM --></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Thorshammer @ May 8 2005, 05:54 PM)</td></tr><tr><td id='QUOTE'><!-- QuoteEBegin -->But also the clutch release pivot point could be off. Or the depth of the flywheel. check it all. Erik<!-- QuoteEnd --></td></tr></table><span class='postcolor'><!-- QuoteEEnd --> Thanks everyone for each of your suggestions. I made a list and checked each item. The clutch cable is new and has slack in it where it connects to the clutch fork. The pivot fork seems to be properly located with space on either side of it at the bell housing. I remember installing the pivot ball all the way in with no spacers behind it. The pressure plate tangs are even and there are no cracks in the spring pieces and the large rivets are tight. The flywheel is brand new and has not been resurfaced. However, I would like to check the depth of the surface to make sure I was provided the right flywheel. I could not find any info in my Haynes manual. Does anyone know what exactly I need to measure and what the spec should be? |
Lo-Fi Version | Time is now: 25th June 2024 - 12:31 AM |
