> 914 Subaru engine cradle?
IanJ
post Apr 9 2012, 05:37 AM
Region Association: Australia and New Zealand
OK...I thought about putting this in the wanted thread (Apologies to the mods if this breaches rules, please delete if inappropriate)
Does anyone know where I can get an engine cradle for converting my 914 using the WRX engine and transmission?
I know you can buy from a few sources and mod to suit but my fabrication skills are lacking and i'd need to pass an engineering check here in Aus.
Any info/leads appreciated.
IanJ
post Apr 9 2012, 08:05 AM
Thanks but I believe even the renegade one needs modifying when using the subaru transmission.
pktzygt
post Apr 9 2012, 02:15 PM
QUOTE(IanJ @ Apr 9 2012, 10:05 AM) *
It does, but one thing to look out for is that the cradle doesn't block something important (like the oil filter) when installed. The renegade one does not and the one posted above looks to have plenty of clearance too. I want to say that there is/was a cradle from smallcar that had this problem, but don't quote me on it.
I'll be modifying my renegade cradle when I get around to the suby trans, but that is only because I already have it and I have some fab skills. I'm definitely not knocking on the cradle posted above, it looks good!
dlo914
post Apr 17 2012, 11:50 AM
Whatchu' lookin' at?!?!
QUOTE(pktzygt @ Apr 9 2012, 01:15 PM) *
For our project we used the Small car engine mount, we only used the two arms that attached to the motor and then connected them together with some angle iron and then bolted it to the stock engine bar. it required a 1/4" spacer to clear the shift rod hole b/c of the thermostat housing, but then we still had to grind down the top of the shift rod hole for more clearance. We could've just added a thicker spacer, but then the starter would've hit the bottom of the trunk. Here's a picture of our car from underneath and the small car engine mount:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-2697-1334685049.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-2697-1334685140.1.jpg)
DBCooper
post Apr 18 2012, 07:26 PM
14's in the 13's with ATTITUDE
QUOTE(dlo914 @ Apr 17 2012, 10:50 AM) *
I bought those Smallcar mounts too, but ended up not being able to use them. They'd be perfect for N/A motors, cheap, simple and strong, but when you have a turbo motor you need to collect all the exhaust into one location as close to the intake as possible. With that mount you basically block the space in the front of the motor for the exhaust to cross from one side of the motor to the other in the front, and of course the transmission makes it impossible to do it in the back. I shouldn't say impossible, just more difficult, with a lot of custom tubing. Just a heads-up for anyone considering a turbo motor.
IanJ
post Apr 21 2012, 10:54 PM
DBCooper. Do you have measurements for your cut out?
I was just hunting for a thread where someone else cut out the complete section welded in a brace then boxed in. (Can't find it at the moment, if anyone has it bookmarked i'd appreciate a link)
I am thinking this would give the best clearance in there plus could stiffen the chassis for all those extra horses going through the rear.
I was originally going to get a custom exhaust made up but i need to run cats for engineering cert to keep emissions down and being able to run standard exhaust would make that aspect much easier.
I am short on room in the garage at the moment and am hanging off getting my front cut delivered until I am ready for it. So if i could get the mods done to body ready for it, it would be easier.
IanJ   914 Subaru engine cradle?   Apr 9 2012, 05:37 AM
pktzygt   OK...I thought about putting this in the wanted t...   Apr 9 2012, 07:08 AM
IanJ   Thanks but I believe even the renegade one needs m...   Apr 9 2012, 08:05 AM
76-914   Thanks but I believe even the renegade one needs ...   Apr 9 2012, 08:58 AM
IM101   I am just about to start production on the cradles...   Apr 9 2012, 10:22 AM
pktzygt   I am just about to start production on the cradle...   Apr 9 2012, 02:10 PM
pktzygt   Thanks but I believe even the renegade one needs ...   Apr 9 2012, 02:15 PM
dlo914   [quote name='IanJ' post='1663284' date='Apr 9 201...   Apr 17 2012, 11:50 AM
DBCooper   For our project we used the Small car engine moun...   Apr 18 2012, 07:26 PM
IanJ   DBCooper. Do you have measurements for your cut ou...   Apr 21 2012, 10:54 PM
BIGKAT_83   OK...I thought about putting this in the wanted t...   Apr 9 2012, 10:03 AM
matthepcat   Finally!! Someone is doing this!! ...   Apr 9 2012, 11:44 AM
wingnut86   Competition makes your competitors more focused on...   Apr 9 2012, 01:20 PM
76-914   914World Group-By discount?? :agree: Or group ...   Apr 9 2012, 05:27 PM
ChrisNPDrider   :beer2: :popcorn:   Apr 9 2012, 02:17 PM
effutuo101   Just waiting on delivery... :D   Apr 9 2012, 04:27 PM
Brett W   I have built two bars that bolt in and allow use o...   Apr 9 2012, 09:21 PM
wingnut86   Competition makes your competitors more focused on...   Apr 10 2012, 08:17 AM
matthepcat   Brett, RH makes you buy the whole package and not ...   Apr 10 2012, 09:01 AM
IM101   I will be making an official release thread and a ...   Apr 10 2012, 12:30 PM
ChrisNPDrider   Ian - you should visit Camp914, in your area. :sh...   Apr 10 2012, 01:59 PM
r_towle   Is there a decent shifting solution for a subaru t...   Apr 10 2012, 02:18 PM
IM101   Is there a decent shifting solution for a subaru ...   Apr 10 2012, 02:25 PM
FourBlades   Looks like a nice product. Can you run the stock ...   Apr 10 2012, 02:26 PM
IM101   Yes. For fit/non cutting porposes I recomend that...   Apr 10 2012, 02:36 PM
my928s4   I just bought my Subaru EJ205 Engine and it came w...   Apr 10 2012, 02:38 PM
wingnut86   Being a true southerner, I'm for an A/C soluti...   Apr 10 2012, 05:42 PM
partwerks   Will this cradle allow one to use the stock shift ...   Apr 10 2012, 10:31 PM
IM101   my928s4: The ETA is two weekends from now, at leas...   Apr 10 2012, 11:12 PM
pktzygt   I understand the reasoning for placement of motor ...   Apr 11 2012, 12:00 PM
IM101   I understand the reasoning for placement of motor...   Apr 11 2012, 09:09 PM
jimkelly   i have emails from RH that say the suby trans won...   Apr 17 2012, 06:27 AM
DBCooper   I think you're in for a lot of extra work and ...   Apr 17 2012, 07:49 AM
IM101   i have emails from RH that say the suby trans won...   Apr 17 2012, 11:36 AM
IM101   Here are a couple of shots from my first run to ge...   Apr 17 2012, 11:50 AM
jimkelly   any idea what shipping will cost - west coast to e...   Apr 18 2012, 11:22 AM
IM101   Hey thanks man, for shipping UPS quoted about 75...   Apr 18 2012, 02:12 PM
Jake Raby   Nope.. Return was fine but the hand holding was ...   Apr 22 2012, 08:55 AM
Zaney   Hi, With the cradle in the car, does the axle from...   Apr 24 2012, 12:00 PM
jimkelly   hopefully not as it is my understanding that some ...   Apr 24 2012, 12:58 PM
IM101   Hi, With the cradle in the car, does the axle fro...   Apr 24 2012, 01:21 PM
jimkelly   any concerns with the amount of cantilever or thic...   May 15 2012, 11:18 AM
IM101   any concerns with the amount of cantilever or thi...   May 15 2012, 12:13 PM
falconfp2001   Can't wait to order one and since no one else ...   May 16 2012, 10:16 PM
wingnut86   Is there any way to mock up the trunk cuts or theo...   May 17 2012, 05:40 AM
IM101   falconfp2001; Thank you, I am doing ok with capita...   May 17 2012, 11:22 AM
IM101   :Qarl: Look what just showed up! Super amped t...   May 17 2012, 11:29 AM
drdave427   :Qarl: Look what just showed up! Super amped ...   May 17 2012, 01:06 PM
falconfp2001   [quote name='IM101' post='1677247' date='May 17 2...   May 19 2012, 10:10 AM
falconfp2001   :Qarl: Look what just showed up! Super amped ...   May 17 2012, 04:00 PM
Brett W   BTW, on our conversion cradle you don't have t...   May 17 2012, 12:54 PM
IM101   True, however the 500$ (more for exchange rat...   May 18 2012, 01:46 AM
strawman   Why not use modified 911 axle shafts? Dutchman Axl...   May 18 2012, 11:01 PM
charliew   I've been doing other things but just got back...   May 19 2012, 12:19 AM
BIGKAT_83   The axles will work fine BUT... be careful Subaru ...   May 19 2012, 07:46 AM
Brett W   Bob, drive that car over here so I can see it runn...   May 19 2012, 08:49 AM
BIGKAT_83   Brett it is sweet with the EZ30. I even think it f...   May 19 2012, 10:00 AM
IM101   Strawman: Several reasons I decided not to go in t...   May 19 2012, 11:35 AM
IM101   charliew: I have some good ideas brewing with the...   May 19 2012, 12:18 PM
falconfp2001   charliew: I have some good ideas brewing with th...   May 22 2012, 12:18 PM
IM101   Guys some new info on the axles, i didnt want to c...   May 22 2012, 11:08 AM
IM101   Well technically it will work for any subaru engin...   May 22 2012, 01:02 PM
falconfp2001   Well technically it will work for any subaru engi...   May 22 2012, 01:39 PM
falconfp2001   Well technically it will work for any subaru eng...   May 29 2012, 12:35 PM
thenewwazoo   I'm very interested in this thread - I actuall...   May 26 2012, 09:00 PM
Porcharu   I'm very interested in this thread - I actual...   May 29 2012, 12:53 PM
abnrdo   Very interesting. I may not have to build my own ...   May 26 2012, 10:46 PM
thenewwazoo   Just a quick note - if you're planning on buil...   May 27 2012, 05:27 PM
IM101   Interesting, I’d appreciate a picture of the mou...   May 29 2012, 11:38 AM
Lennies914   Any updates? I just bought my roller yesterday and...   Jul 22 2012, 12:53 PM
badmiata   Awesome thread, you've got about a yr before I...   Jul 22 2012, 02:07 PM
IM101   Im going to try and not jinx myself, but it seems ...   Jul 22 2012, 04:45 PM
falconfp2001   Cool deal. If the cradle is going to run about 500...   Jul 22 2012, 07:57 PM
my928s4   Any progress on the production run?   Aug 6 2012, 02:58 PM
IM101   MAN IM PUMPED! here is the update: http://www...   Aug 6 2012, 08:26 PM
matthepcat   Very Cool! Talk about upsetting the RH crew th...   Aug 7 2012, 01:48 PM
- Lo-Fi Version Time is now: 28th December 2024 - 05:07 AM
