> Exhaust Leaks, Need Guidance
2-OH!
post May 24 2004, 01:06 PM
75 - 2.0
Dave Hunt and other victims:
Just got 2-OH! started this weekend, still runs shitty, but that's another story...
What I'm bothering you about is your exhaust leaks...I assume you had a bad seal between the heads, the copper gaskets and the manifolds...
How did you know...and a quick and dirty on how you fixed em'...The nuts are torqued correctly, and honestly, I would hate to torque them any more...Afraid of breakage...
With the car running, I get a pretty good downdraft of hot air if I hold my hand under the manifold area...Not scorching enough so that I have to move my hand but hot none-the-less...But is that blow-by or just the cooling fan/tin/ducting/cooling air moving over the cylinder heads doing it's job and exiting under the car...
When running, it doesn't backfire or spit...How can I tell if the manifolds are sealed or not...
New gaskets, new nuts, old manifolds but they fit right in, fresh head rework with a couple of new studs...
2-OH!
2-OH!
post May 25 2004, 10:26 AM
The J tubes are a bitch and thats where I'm feelin' the air...But it's not pulsing, or spittin', or burpin' so I think i'm OK...It's just fan cooling air...I haven't had a chance to check it out since all the suggestions...
I used a small smear of high-temp RTV to hold the copper gaskets in place let it dry while I "persuaded" the J tubes onto the studs...But, they were not that hard...
2-OH!
- Lo-Fi Version Time is now: 6th January 2025 - 05:42 PM
