Pedal Cluster |
Pedal Cluster |
Bullet |
May 26 2004, 12:06 AM
Member Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 |
I'm trying to remove my pedal cluster so that i can replace the pedal bushings. I was able to remove the 2 nuts towards the drivers seat. But the 2 against the bulk head i cant get a soket on them. I crawled way up under there to take a closer look and see what looks like welds on the bold heads. At first i thought it was just some corrosion but after about 50 hard whacks with a chisle i am convinced that they are welds. My qestions is: how the hell do i get theese last 2 bolts out?
Mueller |
May 26 2004, 12:09 AM
wrong side !!!!!
you need to access the two nuts from underneath the vehicle (IMG:style_emoticons/default/wink.gif) you cannot use a socket, a 13mm open/closed wrench is a better tool |
Lo-Fi Version | Time is now: 29th June 2024 - 04:32 AM |
