Pedal Cluster |
Pedal Cluster |
Bullet |
May 26 2004, 12:06 AM
Member Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 |
I'm trying to remove my pedal cluster so that i can replace the pedal bushings. I was able to remove the 2 nuts towards the drivers seat. But the 2 against the bulk head i cant get a soket on them. I crawled way up under there to take a closer look and see what looks like welds on the bold heads. At first i thought it was just some corrosion but after about 50 hard whacks with a chisle i am convinced that they are welds. My qestions is: how the hell do i get theese last 2 bolts out?
Trekkor |
May 26 2004, 12:29 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Actually, the studs are tack welded to the pan. The ped-assym is fitted over the studs and held in place with 13mm nuts. This area is a rust pond if water leaks into your car...Like mine.
I just did this. The studs will shear off. Use an air chisel to press the old studs out. Have an assistant help you by holding a wrench on new bolts or weld in new studs. No problem! |
Lo-Fi Version | Time is now: 28th September 2024 - 06:08 PM |
