Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
I'm trying to remove my pedal cluster so that i can replace the pedal bushings. I was able to remove the 2 nuts towards the drivers seat. But the 2 against the bulk head i cant get a soket on them. I crawled way up under there to take a closer look and see what looks like welds on the bold heads. At first i thought it was just some corrosion but after about 50 hard whacks with a chisle i am convinced that they are welds. My qestions is: how the hell do i get theese last 2 bolts out?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
The pictures may seem unclear because the body is actually sandwiched between the master cylinder and the pedal assembly. Hope that helps.
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 29th June 2024 - 04:37 AM |
